Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
11 members (dt235sd, BC59, cmayna, 66flea, Bill Hanlon, Otto Skorzeny, greenie-reddy, TexasFarmTruck, DennisM, Thom75, 1 invisible), 187 guests, and 4 robots.
Topics128,282
Posts1,058,497
Members48,490
#928958 03/20/2013 10:17 AM
I am sure someone has asked this before but I cannot fine the answer so here goes. MY 55 235 engine has a rv cam in it and headers etc Someone put a 600 cfm on it and that appears to be to much carb, Has anyone used the 390 holley and if so how do you like it. Any ideas will be helpful thanks,
I would like to see a photo of a medium size 4 bbl on a manifold made for a single bbl card. The adaptor must look really strange on there. Can you post a picture?
I have 2 two bbl carbs and they require adaptors too and look weird enough.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I think he had one of these 53moneypit, clifford intake
I have heard the 4 barrel setups run rich in the center. I think some have had issues with tuning, but I'm just going off of memory here. Try doing a search for 390 holley. I know several people have done it.
58' 3200 235 3-speed/OD
