4 members (MikeE, Wayne67vert, TexasA&M48Truck, Opelika Tom), 58 guests, and 0 robots.
Topics128,091
Posts1,056,037
Members48,433
#925474 03/07/2013 9:20 AM
Bought me a 53-3100 last week, just now starting to inspect it and take a bunch of pics prior to working on her. The turn signals didn't work, and the charging system is not working either. The regultor needs replacing, and look what I found under the dash, a bunch of bare wires. The previous owner should be shot, guess I should of looked under there. I unhooked the neg. terminal so the thing didn't burn the garage down with the truck in it in the mean time.
http://www.nloc.net/photopost/data/2692/medium/01218.JPG
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
sstock #925480 03/07/2013 9:40 AM
I've seen/bought trucks with much worse looking wiring under the dash, especially when turn-signals have been added.
That job looks like: "Get 'er done - out of sight, out of mind, . . until you smell smoke, if you are lucky.
sstock #925563 03/07/2013 4:37 PM
At least yours is plastic covered, mine was rotted cloth ... basically just +60yr old dust covering brittle wires.
sstock #925570 03/07/2013 5:13 PM
wasn't the 53 still the cloth covered wiring? maybe yours has already been replaced, just poorly - looks pretty good compared to most 60 year old trucks, just need to solder and heat shrink cover the patches properly wink
sstock #925599 03/07/2013 7:12 PM
Yup, weather should be nice tomorrow, should be an enjoyable challenge, lucky I know my way round auto wiring.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
sstock #925614 03/07/2013 8:26 PM
In my opinion, if you're gonna keep it basic (either 6 or 12v), get the $150 harness from Classic Parts and rewire the entire truck. It's an easy job, I did it over a weekend without rushing but if you focus you could probably do it in a day especially if you are familiar with automotive wiring.
Good luck and let us know how it turns out!
Now this here's some ugly wiring!
Yeah, do what Bluemeanie said.....and if you do go aftermarket wiring kit, don't cheap out- there is a difference!
ugly wiring!
Don J wave
1964 Chevy Panel
"The Good Karma Project"
More pix on Photobucket
1957 Chevy Panel
May be goin' to Hell in a bucket, but at least I'm enjoying the ride! ~ Jerry Garcia
sstock #927292 03/13/2013 7:57 PM
mine was nuttin but ol cotton wrapped wire disintagrated to nuttin with bare wires showin everywhere but i finished re wirin it all today :)(all cotton wrap wire) ran my last 2 wires to the horn and checked everything...it'll all be better once its done and ur rollin down the road
sstock #927328 03/13/2013 10:49 PM
My '56 came with most of the under dash wired with yellow wire and the original wires tangled up in that rats nest.
sstock #927350 03/14/2013 4:24 AM
I agree with red58
Bill is right in seeing that that is not the orig harness to the truck,it,s plastic covered.
Either way You have it beat in that you have a heads up on wiring.
If it were me,I would just clean up whats there,The CORRECT Way,and fire it up.
steve sr.
sstock #928802 03/19/2013 7:27 PM
If you're going to keep the truck,I'm with BLUEMEANIE. for a NEW wiring-harness,that's a good price. once the job is complete,you have nothing to worry about. They usually add more circuits,than the stock fuseblock. Now if you want to add accessories,you can,with no worries. I've gone both ways,and by the time you trace-down wires that go from 2'red,to 8"green,to 23"orange-yeah,you've seen'em.Every joint in a wire,causes more resistance,causing heat,and less juice,where it was intended. new harness=seamless wires. Less chance for shorts,or mis-connections. Just my opinion.
Mo' Tater
sstock #930628 03/26/2013 10:23 AM
There must be a lot of cheap, yellow wire out there. I got a huge roll of wire and a couple of boxes of Scotchloks out of my '71 before I got to the burned out under dash harness! I like using the original fusebox and bulkhead connectors if possible, but id a new harness has those, I'd say go for it.
Les
sstock #930756 03/26/2013 5:59 PM
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
I started the resto on my 53 and every time I turn over a new rock I get a surprise. Look what the PO did, installed too long of a fuse in the heater switch and yo couldn't put a piece of paper between the hot side of the fuse and dash. It is a wonder this truck hasn't burned down as well as my garage.
http://www.nloc.net/photopost/data/2692/medium/P1180518.JPG
I pulled the drums off the rear brakes the other day and found a fresh brake job, only problem is the PO installed the primary and secondary shoes reversed. Didn't matter anyway it all is going in the trash because he didn't replace the leaky axle seal. I'm going through everything now, taking nothing for granted.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
For anyone else out there wondering the correct fuse for the recirc heater is SFE-14.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
