1 members (Truckrolet),
156
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I got a new sway bar from CPP, but it won't mount correctly to the front cross member of my GMC because it's different than a Chevy cross member. I need to fabricate something to carry the flat plane of the bottom of the cross member outboard a few inches. I've seen brackets made to accomplish this that are bolted on. A mechanic friend of mine has offered to weld brackets onto the crossmember, but I wonder if there is any reason not to. Will welding to the cross member cause structural or other problems? | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I think it will be fine to weld to the cross member. I modded my rear cross member (involved welding) without issues. | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | The only thing ruined is originality. There is always a way to accomplish something without drilling extra holes or welding. But if its not something in great factory stock shape, go for it.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | I got a new sway bar from CPP, but it won't mount correctly to the front cross member of my GMC because it's different than a Chevy cross member. i would go back to cpp and talk to them. you might want to venture over here http://oldgmctrucks.infopop.cc/evesome guys have them and some are in the midst of putting them on. i dont recall any welding so check it out. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Oldcarkook suggests bolting a flat steel plate to the bottom of the crossmember that extends far enough on each side to bolt the Chevy mounts to it. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I have a real problem with altering the truck in any way that can't easily be undone. I think I'll put off installing the sway bar untill I can do something 'bolt-on'. Thanks guys  | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | what cletis is saying is a bolt on | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | And I am ageeing with cletis. And Truckrolet. | | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | How far to forward is it? Look at this tech tip from my '37. http://www.stovebolt.com/techtips/driveline/swaybar/index.htmlI used the same sway bar you have which was really long for this chassis. I went over the axle and mounted it behind. It works just the same way and gave me the clearance I needed to mount it with bolt on brackets. There is no danger of it ever getting hit by the axle or frame and if it does, you did something very wrong and that would be the least of your worries. Joe | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I think I would bolt on instead of welding. I like the option of removal if not what I'm looking for. But again it's your truck & it's whatever you feel comfortable doing. Good luck. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | My Chevy CCP sway bar came with triangular shape flat brackets that bolted to the bottom of the spring bolts. You are saying you didn't get those or those won't work on your GMC?
Drew
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | DrewP, my sway bar came with the same triangular brackets, which I have installed. The problem is with the other end of the sway bar, where it mounts to the front cross member. The GMC cross member drops down in the middle because the GMC engines are longer. http://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/633004236/m/19120719073?r=33220629073#33220629073 You'll have to scroll to the top. I'm surprised CPP and others don't offer a 'GMC mounting kit'. | | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | | | |
