2 members (2-Ton, 1 invisible), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#928481 03/18/2013 1:47 PM
I recently recieved this from a new viewer so I am submitting it to the forum regulars for appropriate response. No name was given unfortunately.
"hello
i browsed the site for information
i am not a member but have hard time finding help
i would like to put a 91 truck engine onto the sm318 3speed
originally this trans was mated to the 327 2 bbl in the 65 c10
the bellhousing fits the back of the 350 ( tbi centerbolt heads 1 piece rear main seal) with the 350 flywheel but i did not have the clutch on
crank turned freely
before i go further, should i go with the 327 flywheel....im some i will have issues with the crank since the 350 is externally ballanced
the 327 has a 12" clutch
a vortec flywheel with 168 teeth is compatible with 12" clutch so im told
being 65, is the bell housing same as the 68-91 manual 4-11/16" housings?
would i need a spacer or adapter for the fork or shaft?
any wisdom tips or links to search would be appreciated
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
You might have better luck with a later engine question in the Hi-Po shop.
3B Offline
Hy guys. after the small block was converted to a one piece rear main seal design (1986 ?) the flywheel bolt pattern changed, so you cannot use the older flywheel on the newer engine. Other than that I think all the rest of the components mentioned will work together as is, hope that helps.
