| | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I recently recieved this from a new viewer so I am submitting it to the forum regulars for appropriate response. No name was given unfortunately.
"hello i browsed the site for information i am not a member but have hard time finding help i would like to put a 91 truck engine onto the sm318 3speed originally this trans was mated to the 327 2 bbl in the 65 c10 the bellhousing fits the back of the 350 ( tbi centerbolt heads 1 piece rear main seal) with the 350 flywheel but i did not have the clutch on crank turned freely before i go further, should i go with the 327 flywheel....im some i will have issues with the crank since the 350 is externally ballanced the 327 has a 12" clutch a vortec flywheel with 168 teeth is compatible with 12" clutch so im told being 65, is the bell housing same as the 68-91 manual 4-11/16" housings? would i need a spacer or adapter for the fork or shaft? any wisdom tips or links to search would be appreciated
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You might have better luck with a later engine question in the Hi-Po shop. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys. after the small block was converted to a one piece rear main seal design (1986 ?) the flywheel bolt pattern changed, so you cannot use the older flywheel on the newer engine. Other than that I think all the rest of the components mentioned will work together as is, hope that helps. | | |
