Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (68ironhead, JW51, Greg_H, Peggy M, TUTS 59), 69 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#92821 08/29/2005 4:29 AM
I'm having a problem with the foot pedal starter switch on my '54 (I mean the actual contactor mounted on the starter itself) . It gets stuck ie: keeps running the starter until I yank the battery cable. I burned up one switch and just put a new one on and had it stick again, but this time I was quicker yanking the cable and had no damage. I put the cable back on and it started up fine. I also took the starter apart and checked everything for shorts and she was good. Any ideas?
#92822 08/29/2005 4:38 AM
Try lubricating the foot start shaft at the two places where it is attached to the bellhousing, make sure there is no binding and that nothing jams the starter pedal on the toeboard. More likely a mechanical problem than electrical.
#92823 08/29/2005 4:41 AM
Sound like ya might need a stronger return spring, or just replace the worn one.
#92824 08/29/2005 7:58 PM
I had that problem on my 46. I sprayed the button of the switch with some silicone, problem solved.
Good luck
George
#92825 08/30/2005 4:25 AM
Thanks for the advice guys, I was thinking it was probably a mechanical problem. Just a couple of days before I had the problem the first time though, I dropped it off at a local garage to get an inspection sticker and they had to call at work to ask how to start it. Maybe they tried doing it under the hood and bent something - I'll have to check.
#92826 08/30/2005 2:20 PM
Quote
Oh, that's not good...
#92827 08/30/2005 7:10 PM
Big Bolt Shop Curmudgeon
When the starter motor drive and the foot pedal linkage do not return after the engine starts, there are four possibilities for trouble; three involve a spring used to return a mechanical device to rest; one involves something bent.
The foot pedal linkage has a visible spring (Number 1) just above the starter motor housing that returns the pedal and linkage to rest. The linkage is separate from and not mechanically connected to the starter motor stuff. When you mash down on the starter pedal, all the linkage does is push on the lever that moves the yoke inside the starter motor. That starter motor lever then presses the button on the electrical switch mounted on top of the starter motor housing.
The electrical switch mounted on top of the starter motor also has a spring (Number 2) that returns the switch button and electrical contact to rest.
Finally, there is a spring (Number 3) that is internal in the starter motor that returns the starter motor armature and bendix drive to rest.
You can test to find out where the problem may lie. Try it first with the key off so the engine won't start.
Test the foot pedal linkage by mashing down on the starter pedal until the last possible moment before the starter motor begins to turn the engine. Take your foot off the starter pedal and see if everything quickly returns to rest. It probably will, but this is the easiest test of springs and linkage. Try it several times, as mechanical gremlins have a way of avoiding detection. If the foot pedal and linkage do not return to rest quickly, the problem most likely lies with the foot-pedal linkage. Check for bent or binding things.
Next, with the key off, mash down on the starter pedal to engage the starter motor drive pinion into the flywheel and run the starter motor (not for very long, of course).
If the starter motor won't "hang up" with the key off, try later with the key on.
With the key off, if the starter motor "hangs up", check to see if the foot pedal linkage is binding or loose by pulling up on the foot pedal with your toe or hand. If the linkage is loose, but the starter motor is still "hung up" and running, is the starter motor still engaged with the flywheel and trying start the engine or is the starter motor just sitting out there spinning away wasting battery?
If the foot-pedal linkage is loose and the starter motor is spinning away, doing nothing, not turning the engine over, then the spring (Number 2) inside the electrical switch on top of the starter motor is bad. You said you already replaced the electrical switch, so I doubt that this is the culprit.
If the foot-pedal linkage is loose but the starter motor remains engaged and is trying to start the engine, then I would suspect the internal spring (Number 3) that returns the starter motor armature to rest.
If the foot-pedal linkage is not loose when the starter motor "hangs up" then either the foot-pedal linkage spring (Number 1) is bad, or the linkage has a bind somewhere. If you have lubricated the linkage bearing points, then the linkage is REALLY binding somewhere. Sounds like the hawnyocks that don't know s**t about stovebolts may be at fault.
Let us know.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
#92828 08/31/2005 3:37 AM
Glenn,
Thanks for the thorough analysis. I went over evrything tonite and noticed one of the linkage pivot points was a little rusty from sitting unused while I tore down the truck and painted it these last 8 months. It's possible it got a little wet in the process.
#92829 08/31/2005 3:41 AM
Glenn,
I lubed it all up and tried it out with out the key and it seems fine, but I may put a stronger spring on the linkage just in case. I also noticed that the spring passes very close to the frame to engine gound connection and could possibly hang up at that point.
Thanks again for all the suggestions.
