5 members (Jon G, Otto Skorzeny, Hanks custodian, dt235sd, 3800GUY), 166 guests, and 1 robot.
Topics128,105
Posts1,056,205
Members48,436
#92786 08/28/2005 2:33 AM
Junior Member
Junior Member
Hello,
I have 1952 1 ton (6V) and the battery box is currently under the hood. I know it should be under the pass side floor. I need help figuring out where to hook up the battery cables. There are no cables on it since I just bought it. This is my first old truck so I am running blind. My Dad has a bunch of books but they are packed up and I probably won't get them mailed to me until Christmas! So any help here is appreciated. Thanks
Darren
Chevy = negative post to the firewall, frame, or a bolt on the bellhousing, also a ground strap from the firewall to the frame and/or bellhousing [works best if all 3 are well grounded together] - positive post to the big post on the starter - should work for the basic functions if everything else is wired reasonably right
Be sure to get big fat cables for your 6 volt system, not the skinny modern type. If your local auto parts dealer doesn't carry them your local tractor dealer does. If you can get straps for the ground instead of cables.
Quote
I have two gauge on mine. Larger works well to. (0/00)
I
I Offline
Welding leads make excellent cables for six volt systems.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
Junior Member
Junior Member
Thanks for the replies. I will post back if I run into trouble.
Darren
Junior Member
Junior Member
Hello,
OK, I got the cable but forgive me for being dense but I have no clue what I am doing. I have two wires to hook up. One coming off one contact from the coil (The other wire on the coil comes from the distributer). I assume this wire has to connect to the starter. I also have to connect the positive battery cable to the starter as well. IN the image I have three points marked. Which ones need wires connected to them. The one marked "A" is a large brass looking bolt. I can't seems to loosen it off. My Dad thinks I have to attach both the coil wire and the battery lead to it. Help!
[img]http://www.mlsd66.ca/~dforbes/starter.jpg[/img]
Darren
You are missing your starter switch. "A" is where the switch should make contact and it will be covered by the switch when it is installed. "B" and "C" are the screws that hold the switch in place. There will be a large terminal on the switch for the positive cable. (if this is a GMC make that negative cable)
Another wire(10 guage) will run from there to your amp guage. The wire from the coil should run to your ignition switch.
Junior Member
Junior Member
MMM, Starter Switch eh? The wire from the coil should run to the Igintion Switch? It has an "O" end on it as though it should be screwed down to something. I will have to find this starter switch first. Thanks. I will be posting again for advice.
Darren
Junior Member
Junior Member
OK,
I understand the starter Switch to be that knob on the floor. When I push it it is connected to a rod that moves a lever on the starter. Do you mean the Solenoid? Does anyone have a picture of what it should look like. I am a retard. I am guessing here.
Darren
X
X Offline
Here\'s a picture of the starter switch. The lever on the starter also pushes the button on this switch. The button makes electrical contact with that copper nub (A) on the starter.
Here\'s a wiring diagram (a PDF file) for a '54 truck, which is pretty much the same as the '52. Just ignore the right drive (RD) starter with solenoid and dash push button shown in the diagram.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Junior Member
Junior Member
Thanks alot Curt,
I will keep you all posted on my progress.
Darren
