5 members (lumbersawyer, Nick in Manitou, Wally / Montana, Sjm, Peggy M), 135 guests, and 4 robots.
Topics128,264
Posts1,058,357
Members48,485
#927278 03/13/2013 7:25 PM
I have a 53 1/2 to and am looking for affordable tires for daily driving. No highway. The truck came with 7.5 x 16. Any suggestions other than Coker?
Thanks.
Scott60 #927286 03/13/2013 7:38 PM
a modern day replacement radial tire size is 215/85R16. Many discussions on the subject.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Scott60 #927291 03/13/2013 7:56 PM
Check the Diamondback brand as well. On page 22 of their online catalog is a radial that replaces the 6.00X16 pretty well. www.dbtires.com
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Scott60 #927302 03/13/2013 8:48 PM
Here's a comparison of a 225/75/16 and a 245/70/16 next to a 7.00/15. The 225 basically the same height and width. The 7.5/16 you have on your truck are pretty tall. They would've came from the factory with 6.00/16 or 6.50/16. I'm guessing someone went with the taller tires to make it a little more highway friendly. Hope this helps.
http://s1074.beta.photobucket.com/u...amp;_suid=136322861393807965292815299749
http://s1074.beta.photobucket.com/user/whitedog76/media/P1020303.jpg.html?sort=6&o=31
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Scott60 #927355 03/14/2013 5:43 AM
The base wheel on 1953 1/2 ton was a 16x4.5.
But, the truck could have come from the factory with optional 15" wheels (RPO-273H 6-bolt 15x5.5 wheels). The tire was a 6.70x16. It looks like the same size tire was base equipment on 3600 trucks (8-bolt 15x5.5 wheels)
As Whitedog posted, the optional 15" wheels would not have come from the factory with 7.50 tires. I have run 7.50x15 Toyo radials on those RPO 15" 1/2 ton rims.
Scott60 #927410 03/14/2013 10:29 AM
Crusing in the Passing Lane
235x85x16 or 80x17 will be a little larger than stock, but will help cruising RPM some.
Scott60 #927451 03/14/2013 3:20 PM
If you're looking for wide white walls they're all pretty expensive. I went with 15" wheels and 215/75/R15 with a narrower ww. Got tires from Amazon @ $75 ea. I love the wide ones but not willing to pay $250+ per tire. Mine is a 49 half ton and my stock rims were 4" and would not clear disc brakes w/o some grinding..
New wheels and tires are not on yet so my photo collection is still with the stock setup.
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
