0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92718 08/22/2005 3:40 AM | Joined: May 2005 Posts: 20 Apprentice | | Apprentice Joined: May 2005 Posts: 20 | I've got a 350 Chevy engine that I am building to put in my 1929 1.5 ton Chevy truck. I am wondering if anyone here can help me with a wiring question. I need to know how to wire up the HEI distributor (which wire is the hot wire, which is the ground ect...). My problem is wiring from a one wire system to a four wire system on the distributor. I've done some searching on the web and can't seem to locate any schematic information to help me with this. Any help or direction would be appreciated.
Thanks! | | |
#92719 08/22/2005 4:12 AM | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | I'm sure others will have more information but this is what I have:
I still have the 235. I'm using a S10 HEI distrubutor and external coil. The wire from the ignition to the positive side of the coil had a resistor. My instructions said to remove it. My distributor has two wires. One wire (pink) goes to the positive side of the coil and the other (brown) goes to the negative side of the coil.
Hope this helps. | | |
#92720 08/22/2005 6:26 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | The white wire goes to the ESC(Electronic Spark Control) connection on the ECM. The ppl/wht goes to a reference voltage, also in the ECM. The tan/blk goes to a easily accessable male/female plug that is disconnected to check timing and then on to the ECM. The blk/red is grounded inside the ECM.
If none of this sounds right and I suspect it doesn't, you need an earlier HEI. Look for one with a vacuum advance on the side and a "BAT" and "TACH" connection on the cap.
'67 GMC 3/4 292 4spd
#92721 08/22/2005 7:17 PM | Joined: May 2005 Posts: 20 Apprentice | | Apprentice Joined: May 2005 Posts: 20 | Thanks for your replies, you've been a great help! I am headed to the salvage to get another distributor. | | |
#92722 08/23/2005 3:21 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | ok colors ... I know I'll just ask advise, can't hurt. I have an HEI that I'm getting ready to make the 'plug-in' wire up to the new wiring harness. It has an Accel top mounted coil. Because I am not familiar w/ Chevy stock color codes what are the three wires at the dist: black = brown = pink or beigh = These three plug into the Accel coil w/ two other vacant plugs (wire leads) that are in the cap, BAT and TACH. The BAT must go to the ignition post of the key switch ??? because the coil is 'internal' (mounted on top), the key switch supplies the voltage to this unit. ?? So while you answer I'll go open it up and see what's what. Is this a possible tach feed wire? thanks for the input gooday jim
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#92723 08/26/2005 1:39 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | yup...that goes to the ign switch.. the other is for a tach the old HEI only needs one wire,,,not resisted that goes to the switch.....uhhhhh on the four wire cap.. uhhhhhh if its like this from the front of the engine lookin down on the top of the cap like this II II if thats the four wires then the ign goes to the top right one....hows that..???
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#92724 08/27/2005 1:18 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Fatweed are you suggesting that the four wire type can be run with just the ignition connection? I've never played with one that new...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#92725 08/27/2005 3:22 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | yup if i remember right...im sure its that way... the other two wires were for sumthin unrelated.. like some computer monitor or something,,,cant remember.....
#92726 08/27/2005 4:20 AM | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | The 4-wire distributor without the vacuum advance needs a computer to work properly, and a couple of inputs from places other than the distributor. The electronic spark control distributor does not have centrifugal or vacuum advance, and I don't know of any way to make it work on a non-computer engine. On the one with the mechanical advance, just put 12 volts to the "Bat" terminal on the cap, with at least a #10 wire from the ignition switch to the distributor. The 3-wire plug from the distributor housing to the cap completes the circuit, so don't forget to connect that one! Jerry
#92727 08/27/2005 6:58 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | Thanks guys I've been doing my home work but I still have one question that I can not find a good complete answer to.
posted 08-23-2005 01:42 AM -------------------------------------------------------------------------------- Some info says how easy or one wire hookup about wiring an HEI to your truck and little about the related starter. Most times the starter does not enter into the info. The original wiring did not have a Bypass wire from the plus side of the 'ign' & coil to the starter 'R' post. This way the coil ''only in start mode'' has full 12volt positive at the coil. The standard wiring had a resistor allowing about 9 += volts to the std. points dist. /coil during operation. When wiring for an HEI it is suggested to use a larger size wire 10-14 ga. should be placed to the HEI 'BAT' from the key switch ignition post and remove the resistor wire. I have also found notes on eliminating the 'Bypass' wire from 'R' to coil when installing an HEI. Comments please... my truck has HEI installed ???????? WHICH WAY TO WIRE... Have the 10-12ga. bypass @ (starter solonid R) and the 'IGN' @ ket switch OR use the (my) 14gauge (I might change this to 10-12 but I'm also wiring a starter relay setup so 10 ga is overkill) wire that only runs to the starter (S) post and my key switch 'start' post, (eliminate the ByPass wire ??? which as i think about this, I rather like having that extra effort at starting only.
eliminate resistor wire !!!! which can be used (if applicable) for the idiot lamp on a three wire alt'r set up.
Then we can talk about the relay for this circuit. I'm now in the process of wiring several sets of relays off a separate fuse panel to horn, hi/low lamps, starter, fog/driving lamps &?? the tricky part will be the relay to HIGH beams and killing driving lamps when in low. it should be fun. gooday jim
Gooday Jim
#92728 08/27/2005 3:03 PM | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | If the wire from the ignition switch to the coil is replaced with a correct-size wire, there's no need for a bypass. The only time there is voltage on that starter solenoid lead is during cranking, and there's already full battery voltage to the coil if you've eliminated the resistor. The reason for the larger wire is to minimize voltage drop due to the somewhat higher current draw of the HEI system. Rather than cutting the resistor wire out, I just insulate the end terminal where the old coil was, and connect the heavy wire as close to the ignition switch as possible. Any other circuits the resistor lead feeds aren't affected that way. Jerry
#92729 08/27/2005 4:23 PM | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | The easiest way to hook up HEI is at the key switch. Pull all the original ignition wires out and run one new 10 gauge wire from the dash to the "Batt" terminal of the HEI. Under the dash hook the new wire to the ignition terminal of the key switch. Now take a short piece of the same wire and hook to the start terminal of the key switch, take the other end and hook to the ignition terminal. You now have 12volts in start or run. You need do nothing else. Joe | | |
#92730 08/27/2005 6:00 PM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | that's what I wanted conformation on thank you gentlemen I'll do that today gooday jim
Gooday Jim
#92731 08/27/2005 8:25 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Wiring the driving lamps to go off when low beams are on is easy. Wire one side of a relay coil to the low beam wire and the other side to the switched terminal on the driving lamp switch. Wire the relay common to +12V and wire the relay NO terminal to the driving lamps. The relay coil gets its ground through the low beam filaments except when they are on. The driving lamp switch should get its power from the ignition accessory terminal to prevent any current flow if you forget to turn the driving lights off.
Baldy | | |
