3 members (klhansen, Otto Skorzeny, Wally / Montana), 58 guests, and 2 robots.
Topics128,052
Posts1,055,726
#924310 03/02/2013 9:41 PM
In '09 had had Stockton Wheel put new rims on my stock centers. While at the car wash I noticed one of them is cracked. These rims are welded on. Now I'm wondering if I sent them a bad center or if the welding embrittled the metal. Anyone else had welded wheels crack?
Cracked wheel.
Cletis #924343 03/03/2013 4:56 AM
Haven't had the problem Charlie, but since I've been welding
since I was in short pants, made a living at it for many years
and am now in my 70's, it looks like your getting stress cracks
that start at the edge of the welds.
I can't say for sure but it might have been because the centers
were a tiny bit smaller than the rim ID and when they welded it
and the weld shrank it's putting to much load on the joint.
And again I don't know for sure, but I'd bet that factory welded
rims are stress relieved before they are put into service.
DG
Denny G
Sandwich, IL
Cletis #924344 03/03/2013 5:54 AM
Wow, that is interesting. I have always wondered about the liability of being in that kind of business, reworking older rims. I am going to guess that you can't be the only one with that problem.
1951 1 Ton Completed
Cletis #924400 03/03/2013 10:12 AM
Some time back, right after I brought my '50, 3604 home, I
gathered up a whole bunch of 15" split rims and drilled out the
rivet to get the centers. The plan was to send them to one of
the wheel shops and have them installed in a single piece rim
for radial tires. The problem that Charlie has uncovered is the
exact reason that I've been hesitant to do it.
He's lucky he found it now rather than on the trip up to KC at
75mph.
That can't be the only case that they have run into.
Denny G
Denny G
Sandwich, IL
Cletis #924416 03/03/2013 10:53 AM
Sir Searchalot
Sir Searchalot
Cletis: Maybe this is obvious and is just a reminder. I believe Denny would agree to not run any of them anymore. Cracks are not always visible with the naked eye. That's what dye penetrant and such is for. Was that whole process, sending them away and having them welded, cheaper than finding a set of used or new?
Cletis #924429 03/03/2013 11:33 AM
The weld is only as good as the welder.
"New" will probably be chinese made and I would rather trust a bad welder. I bought a pair for my modern truck after smacking one of my alloys on a curb one icy morning. Never ever got them to balance because the metal was so soft that they bent every time I went around a corner.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Cletis #924431 03/03/2013 11:43 AM
question I'd have is why not find a good set of used 55-60 wheels? I could see Denny insisting on 6 hubcap clips instead of 3, but is there any other real difference?
bartamos #924434 03/03/2013 11:53 AM
Sir Searchalot
Sir Searchalot
Originally Posted by bartamos
Cletis: Was that whole process, sending them away and having them welded, cheaper than finding a set of used or new?
FriedGreen: In the words of a fellow Stovebolter "I hate quoting myself, but"... I did say used or new
Cletis #924497 03/03/2013 3:33 PM
I know, I was just warning on the evils of what you get for new these days. wink
1953 Chevrolet 3600
Cletis #924535 03/03/2013 6:25 PM
Sir Searchalot
Sir Searchalot
Roger
Cletis #924540 03/03/2013 6:39 PM
As you all should know, good used are hard to find. Plus I wanted a wider wheel. A couple of guys on the GMC board had used Stockton and I thought that would be the way to go. I wanted stock looking wheels and stock hubcaps.
Cletis #924558 03/03/2013 8:17 PM
Cletis, what does Stockton have to say?......
Cletis #924560 03/03/2013 8:21 PM
Lets hope this guy didn't weld them
...link...
Don't think thats proper weld prep
I have a set and will be inspecting them thoroughly
Thanks for posting
Cletis #924615 03/03/2013 11:33 PM
I haven't talked to Stockton yet but I plan to.
Dads50, that may be the problem.
Cletis #924679 03/04/2013 10:22 AM
Give them a call first, here's a clip from their "about us" page
Quote
...doing it right. Anybody can weld a wheel, all it takes is a welder. You can even do it out of your house. The trick is to make sure it's round when you're through and that it stays together after you put it on your vehicle. It helps when you're committed to do the kind of job you would want for your own car.
If they stand up for their work and name I expect they'll have a solution for you.
They have a new owner between now and when you had those made right?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Cletis #924680 03/04/2013 10:22 AM
I had new outer rims welded to the centers of my MG TD by Stockton Wheel in 2003. I haven't had any problems. Thank you for posting this Cletis. I will check mine today to see if I have any cracks starting.
1937 Chevy pickup
1952 MGTD
Cletis #924699 03/04/2013 12:01 PM
The company has had changes within the past few years.
Not sure if ownership family or management is the same.
They were closed for a short time and reopened under same name.
Cletis #924705 03/04/2013 12:22 PM
Cletis #926339 03/10/2013 7:39 PM
I finally got around to pulling the wheels. The other 3 appear to be OK. Here is a pic of the cracked one. Two welds completely cracked down the middle.
Cletis #926409 03/10/2013 11:13 PM
Scary!
GMC: Get More Cash...
1958 GMC
My Webshots photos
Cletis #926523 03/11/2013 11:51 AM
Wow, that's not good!
Cletis #926821 03/12/2013 8:36 AM
I bought AMERICAN made alloy(eagle) wheels made in Sacramento California. Lifetime WARRANTY.
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Cletis #926822 03/12/2013 8:42 AM
After looking at your pictures that is a total weld failure. If it was a metal fatigue problem the crack would of been down either side of the weld not down the center of the weld. I should mention that the secondary cracks were caused by weld failure causing stress on the other part of the wheel.I would be calling them to get it repaired on their dime. Good luck.
"IT IS WHAT IT IS"
In the DITY Gallery
1953 Chevy 1-Ton
