Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Hotrod Lincoln, ShopRag, 59 fleet, Otto Skorzeny, Gdads51), 58 guests, and 1 robot.
Topics128,009
Posts1,055,291
Members48,419
#92665 08/17/2005 2:22 PM
I have a vintage replacement headlight switch in my dash. It has connection terminals for the park,headlight,stoplight,instrument (reostat) and battery. There is an intregal fuse with a terminal at the back of assembly opposite the "bat" terminal. Is this where the dome and tailight wires go? Also, what duty voltage reducer needs to go in line to the horn relay when doing 12 volt conversion?
#92666 08/17/2005 2:37 PM
I
I Offline
Not sure about the headlight switch, but the horn/s should be able to handle 12V.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#92667 08/17/2005 6:17 PM
If we knew if this was a 1927 or a 1947 we might be able to tell you more but I can tell you for sure the tail lights and dome light don't come off the same terminal.
#92668 08/17/2005 8:34 PM
Probably for your 51 burb? I found this in a post from a couple of years ago. Look familiar?
Thank tclederman.
[img]http://home.nycap.rr.com/lederman/images/lightswitch.jpg[/img]
Gord
1954 1/2 ton 235 4 speed
#92669 08/17/2005 8:55 PM
Sanderson,
I'm not sure on this, but I don't think you want to switch the STOP lights. These should be hard wired!
Stuart.
#92670 08/18/2005 1:25 AM
If Sanderson has a 1951 Suburban (as in Sanderson's Profile), the Headlamp Switch shown above is very similar to the one in his truck.
The Headlamp "Switch" is fused and serves a variety of functions (it is not just a switch).
1. Battery power (at all times) to the domelight and the stoplight(s).
2. Battery power (at all times) off the rear terminals (one terminal is for battery-in). I think the radio, glovebox light, turn-signals, and heater-motor are examples.
3. Switched power to parking, tail, and headlamps/lights.
4. Switched and rheostat-adjusted power to dash lights (and clock and radio lights, if you have them).
Other electrical components might receive switched or unswitched power from the ignition switch (radio-maybe, cigar lighter, glovebox light-maybe).
Tim
#92671 08/18/2005 2:23 PM
Thanks guys and gals- yes this is for the burb and you've covered my butt again.
