7 members (55shaker, 1955 1 Series, Bill Hanlon, Oswald, Greg_H, Ponchogl, Shade Baby),
140
Mod | | | Forums66 Topics128,261 Posts1,058,345 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92665 08/17/2005 2:22 PM | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | I have a vintage replacement headlight switch in my dash. It has connection terminals for the park,headlight,stoplight,instrument (reostat) and battery. There is an intregal fuse with a terminal at the back of assembly opposite the "bat" terminal. Is this where the dome and tailight wires go? Also, what duty voltage reducer needs to go in line to the horn relay when doing 12 volt conversion? | | |
#92666 08/17/2005 2:37 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Not sure about the headlight switch, but the horn/s should be able to handle 12V. | | |
#92667 08/17/2005 6:17 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If we knew if this was a 1927 or a 1947 we might be able to tell you more but I can tell you for sure the tail lights and dome light don't come off the same terminal. | | |
#92669 08/17/2005 8:55 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Sanderson, I'm not sure on this, but I don't think you want to switch the STOP lights. These should be hard wired!
Stuart. | | |
#92670 08/18/2005 1:25 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If Sanderson has a 1951 Suburban (as in Sanderson's Profile), the Headlamp Switch shown above is very similar to the one in his truck.
The Headlamp "Switch" is fused and serves a variety of functions (it is not just a switch).
1. Battery power (at all times) to the domelight and the stoplight(s).
2. Battery power (at all times) off the rear terminals (one terminal is for battery-in). I think the radio, glovebox light, turn-signals, and heater-motor are examples.
3. Switched power to parking, tail, and headlamps/lights.
4. Switched and rheostat-adjusted power to dash lights (and clock and radio lights, if you have them).
Other electrical components might receive switched or unswitched power from the ignition switch (radio-maybe, cigar lighter, glovebox light-maybe).
Tim | | |
#92671 08/18/2005 2:23 PM | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | Thanks guys and gals- yes this is for the burb and you've covered my butt again. | | |
