2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
#926558 03/11/2013 2:23 PM
Moderated
Moderated
I have a 49 Chevy 3600 with a locked up engine. Ideas to replace it.
Mark987654321 #926617 03/11/2013 5:10 PM
Another 235 or better a 261 if you can find one.
Drew
DrewP #926618 03/11/2013 5:25 PM
I replaced the 216 in my 48 3/4 ton with a chevy 250 cu in engine. THe original 216 (which had a bent rod) was 85 hp and the earlier 250 (mine is a 1967) puts out 155hp which is a nice upgrade but does not over power the truck using the stock tranny and rear end. The 250 bolted up to the oringinal 4 spd.
Mark987654321 #926701 03/11/2013 8:36 PM
230s and 250s are hard to mount. takes alot of work.
id go with a 235 or a 261 like drewp said
there is a 55 235 in greyslake ill. and a 1959 impala 235 in wilminton right now
Mark987654321 #926924 03/12/2013 4:12 PM
Check out the Inliners site. They usually have guys selling engines & parts.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
