| | | Forums66 Topics128,065 Posts1,055,865 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | O.K. gang here I go, i have read about 3 pages of this section. My situation is this, I have 4 wheel disk brakes on my 51 1/2 ton Chevy 3100. I purchased the disc/disc power brake master cylinder set up. Thought this would be pretty straight forward, i am mounting it under the cab in the normal position.1st question is there a specific size of brake line ?? I went to parts store and found out there are about 3 sizes?? Is there a certain size or does it matter?? i bought 3/16th's! Also proportioning valves? From what I have read I need this because of where the system is mounted? help please. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The 3/16 lines should be sufficient. If you bought a kit the proportioning valve should be on the master cylinder. It looks like this on the Performance on Line kit. Read about my installation on my '54 here. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | area51...I too used the underfloor set up but I did not put a proportioning valve and I do not have disc brakes....however, on my 52 there was one line, 1/4" if I remember right, that crossed over to the chassis rail and then it was all 3/16. ...don't know if this applies to your situation or not but just food for thought. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Thanks guys, Cletis that is exactly what mine looks like. Yes the exiting line is 1/4 inch but it will be reduced to the 3/16's. I googled and read a few things last night.i found out about all the different fittings, pipe,ansi, etc... I think i got it figured out but will certainly read your instal. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Cletis read the write up good info, I have my master cylinder and pedal already installed. My disc brakes were not a conversion i have a ford 8.8 rear end.My headache was slightly less than yours. I did have to "make" the assembly fit. I cut some of the stock assembly bracket away to do this worked out fine, about 7 hrs. worth of fitting and grinding?? Again thanks for the info. | | |
