6 members (Otto Skorzeny, 50Chevy3100, frogfarmer, UtahYork, Shaffer's1950, 1 invisible), 67 guests, and 3 robots.
Topics128,056
Posts1,055,804
#925366 03/06/2013 7:29 PM
fired my 216 oilpressure on gauge in oil port 25# as engine warmed oil pressure went to 30 but not solid needle on gauge bouncing in crease rpm oil pressure goes to solid 25 then to solid 23 book says oil pressure sb 15 can it be adjusted? it it ok ran the motor for 1 hour will retork head tomorrow restart warm and set valves concerned about pressure thanks for any help
tigman 1 #925374 03/06/2013 7:42 PM
no you can't adjust it - you only need worry about low oil pressure, 15# is a ballpark minimum, see what happens once the engine is run in
Flxible #925380 03/06/2013 7:50 PM
thanks bill i was just worried as it went up when warm motor is running good has a little knock when idle is turned down to just barely running adjust idle up a little it goes away all rocker arms have oil just concerned about pressure 30 pound gauge will put higher gauge in port tomorrow
tigman 1 #925416 03/06/2013 9:43 PM
headscratch
tigman 1 #925422 03/06/2013 10:02 PM
Ditto
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
tigman 1 #925444 03/07/2013 6:49 AM
I don't know the history of your 216 but I will mention what I have read over time on oil pressure issues. If the oil distributor valve spring is modified to raise the indicated pressure it will result in insufficient flow to the rods and damage will likely occur.
1951 1 Ton Completed
truckernix #925458 03/07/2013 8:33 AM
bought truck it was used as a daily driver took it apart 10 years ago it was running then but the engine smoked rebuilt last fall checked bearings new rings head was cracked thats what the smoke was rebuilt head motor runs fine other than the oil pressure using gauge in oil line port not the original gauge trying to get it mechanically right before putting body on retired pipefitter most things loose pressure upon heating except steam will torque head and run it again today dont think the spring was altered i didnt and dont remember what it was
tigman 1 #925465 03/07/2013 8:54 AM
"bought truck
new rings
rebuilt head
retired pipefitter
i didnt and dont remember what it was"
tigman 1 #925617 03/07/2013 8:49 PM
started 216 today let warm for one half hour set valves motor runs excellent oil press 22 cold 27 warm must be check sticks when warm will watch closly any other help is appreciated
tigman 1 #925685 03/08/2013 5:56 AM
punctuation is really a part of our language...
tigman 1 #925687 03/08/2013 6:08 AM
Maybe the period ("." full-stop) key is broken?
tigman 1 #925708 03/08/2013 8:25 AM
Say speeeeeeeeed!
The oil pressure when a 216 is cold will be about 25-30psi.
The oil pressure when a 216 is warmed up will be about 14-15psi.
The oil pressure when a 216 is idling will be about 6-7psi.
Anything other than that indicates either a problem somewhere
in the system or that someone has modified the system in some way
other than stock, in which case he or they have assumed the title
of "head engineer".
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
tigman 1 #925744 03/08/2013 11:14 AM
My 216 never sems to get abov 8 PSI, but the upper end is getting oil, so I attribute it to the 1948 oil gauge. No problems in five years.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
tigman 1 #925752 03/08/2013 12:04 PM
Not unusual Tom. Probably attributable to the bearings being
worn some. If you ever have a need to pull the pan down it wouldn't
hurt none to reshim them. Might bring up the pressure a bit.
Don't cost that much to pull the cover off the oil pump and see
if the gears are worn or if the bottom of the housing is
showing any wear. Really a simple pump and you can get
rebuiling kits for them. It's also possible that someone put a
homemade gasket under the cover which would lower the output
due to to much clearance (pressure leakage) at the ends of the
gears.
Denny G
Denny G
Sandwich, IL
Flxible #928322 03/17/2013 7:53 PM
not worried about puncuation just oil problem the gauge i used was 0 to 30 face was beat up took lens off vacuum gauge embareassed 7 hot idle 23 high rpm thanks engine is fine
tigman 1 #928438 03/18/2013 10:15 AM
Tigman 1,
Not to be rude but perhaps you should worry about punctuation.
The purpose of this forum is to share information, and even the most laid back (and permissive) of us have difficulty reading your posts and understanding what your questions and problems are with your oil pressure. That is why you got the response from some of the posts earlier in this thread. Even the most finicky of us will sometimes have a typographical error, and are usually forgiven, as long as we can communicate. Here, you have access to some of the best advice possible, with many willing to give you a hand. You just need to help us out a bit.
I am really glad you found the problem and shared the solution with us. That is something for all of us to keep in mind next time we have a similar problem.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
