| | | Forums66 Topics128,012 Posts1,055,316 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | putting in a new speedometer cable in 48 gmc 1/2 ton, the end going into speedometer, has a bell type fitting, does it just slip over and stay in place, i see in back of speedometer has a shaft with threads on it, put old cable and new cable don't have threaded nut on that side of cable... | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | There is a big threaded ring that captures the flare on the cable bell and holds the cable to the back of the speedometer. | | |
