1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#925581 03/07/2013 6:10 PM
putting in a new speedometer cable in 48 gmc 1/2 ton, the end going into speedometer, has a bell type fitting, does it just slip over and stay in place, i see in back of speedometer has a shaft with threads on it, put old cable and new cable don't have threaded nut on that side of cable...
696969 #925582 03/07/2013 6:14 PM
There is a big threaded ring that captures the flare on the cable bell and holds the cable to the back of the speedometer.
696969 #925591 03/07/2013 6:53 PM
Should show that back of the speedo with cable hooked up:
http://www.pbase.com/dennygraham/image/149103461
a little bit blury but get's the point across:
http://www.pbase.com/dennygraham/image/149103462
Denny G
Denny G
Sandwich, IL
