0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#925361 03/06/2013 7:24 PM
lar
Offline
The cab on my 40 originally mounts to the frame using rear rubber mounts and small coil springs in front between the frame and cab. Giving new drivetrainand suspension , should I USE ORGINAL HARDWARE OR GO ANOTHER ROUTE? Thanks larry
lar #925384 03/06/2013 7:55 PM
I plan on using original mounting for my 46 when upgrading this spring. It has worked this long..why change now is my thought.
lar #926524 03/11/2013 11:52 AM
My 46 is mounted solid to the frame. The original mounting is meant for a lot of movement of the cab, and I wanted less movement.
My 46 GMC on Photobucket
