| | | Forums66 Topics128,023 Posts1,055,365 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 18 New Guy | | New Guy Joined: Mar 2012 Posts: 18 | The cab on my 40 originally mounts to the frame using rear rubber mounts and small coil springs in front between the frame and cab. Giving new drivetrainand suspension , should I USE ORGINAL HARDWARE OR GO ANOTHER ROUTE? Thanks larry | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | I plan on using original mounting for my 46 when upgrading this spring. It has worked this long..why change now is my thought. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | My 46 is mounted solid to the frame. The original mounting is meant for a lot of movement of the cab, and I wanted less movement. | | |
