Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Otto Skorzeny, 3B), 131 guests, and 5 robots.
Topics128,274
Posts1,058,436
Members48,490
#924759 03/04/2013 5:29 PM
Hello S/B community, I have a quick question, will a 53 3100 bench seat fit a 49 3100 seat frame? I tried the search function for this and came up empty handed. I'm sorry if this has been covered before. Thank you guys.
JC49 #925084 03/05/2013 6:16 PM
I did this switch to get rid of the cable system that did not work.
You can do it
Dennis
JC49 #925107 03/05/2013 8:01 PM
In 1950 the seat width increased 2-1/2" but I am unsure if the frame mounting changed?
http://www.flickr.com/photos/advance-design_parts_co/8251910066/in/set-72157632186114015
JC49 #925117 03/05/2013 8:23 PM
Brad,
I've asked that question before but no one posted measurements.
I'll post outer side-to-side measurements of the metal base for a 54 if someone posts measurements for pre-50 metal seat base.
In 1950, the seat was also "made more durable by adding turns to the coil springs and by increasing the gauge of the spring wire"(LCVA article).
JC49 #925155 03/05/2013 10:10 PM
I put a seat out of a 50 3100 in my 48 3100. It fits fine.
Dennis
JC49 #925213 03/06/2013 7:57 AM
Ok, where did I go off track on this one Dennis, didn't all of the AD's have a cable and pulley seat adjuster???
Seat frame that's welded to the floor board is 56".
DG
Denny G
Sandwich, IL
JC49 #925221 03/06/2013 8:32 AM
What year (56"), Denny?
I just now looked at a lot of you really old posts, Denny. Many of your old posts are now blank. This problem with the new Stovebolt.com server/software is really a seriously bad problem.
If you width is for a pre-1950, and no one posts a width for a post-50 seat-base, I'll unpack my hibernating 54 and measure the width.
On what part of the base did you span your measuring tape (if that makes a distance). Side-to-side seat base - measured at the rearward side, middle side, forward side.
I do not know if this makes a difference on a regular cab. It makes a difference on my GMC COE seat base, which is different from a Chevrolet standard cab seat base (the COE is the only base I can get to now).
JC49 #925240 03/06/2013 10:26 AM
How bout a '51 and '53, got that out of the spec. sheet body
dimemsions. and took a quick look at mine '50 which looked the
same. Since they're only talking an 1 1/4" on each side it well
might have just been in the uppre cushion band that they
widened it. I don't think the earlier cabs are actually
2 1/2" wider.
I'm not in a position to start trearing either on of my truck
apart right now to take measurements so maybe some one that has
their's in process or in a heated garage can follow up.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
JC49 #925289 03/06/2013 2:06 PM
Thank you guys for the replys, Brad Allen thank you for the link, I did not know they were wider.Mr Graham and tclederman if I get a chance this evening I will measure the inside of the seat frame since it is not in the truck yet (in my storage room) and post the measurements.The reason for this post was that I have an opportunity to buy a used seat and wanted to know for sure.
oldbluetruck, when you did the swap, I take it the seat just dropped in (no mods or alterations) or what else, if anything was done?
JC49 #925415 03/06/2013 9:41 PM
My 48 had the old cable system which did not work. This is the adjustment for the front to back for leg room. I bought the entire seat which included the adjusters, seat frame, and cushions from a 50 3100. I had to remove all the cable adjustments, frame and cushions for the replacement.
I do not remember any width difference. It seems to me the frame and cushion widths were the same
Dennis
JC49 #925419 03/06/2013 9:51 PM
Fixing the cable seat adjusters turned out to be a pretty easy job once I figured out how to cross the cables. Works pretty well.
JC49 #925603 03/07/2013 7:17 PM
I wish that I could have done that. It would have been nice
Dennis
Moderated by  ndkid275, Phak1
