6 members (Gdads51, Forty9, Rusted Nut, 39Master85, BC59, 1 invisible), 94 guests, and 1 robot.
Topics128,132
Posts1,056,376
Members48,441
Gents and ladies,
My steering wheel thread on the column shaft are mashed. I started to use a 1/2 - 20 rethreader but it started to eat more of the tip so I stopped. Is there a way to fix this or will I need to get a new shaft?
Bread
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
I had to rethread mine to that size. The PO had a 14" hot rod steering wheel and he damaged the orginal thread. Go slow, 1/4 turn forward and back. Thread it to get a full Nut.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
If you file the headed area down first I think the tap will work.
My Blog
Dave,
On curiosity,what is the thread pitch on the shaft?
never needed to meas. or chase one on anything I,ve own...lucky I guess.
steve sr.
1/2"-20 is correct.
My Blog
MtneerMike and Pre'68 Dave,
Thanks for the advice and it is competed. I had to cut the tip off, filed the edges down and started the re-threading. Once it grabbed hold, it felt like a was screwing on a nut with a few snags. With a little lube spray, turning 1/4 back and forth, it didn't take any time to finish it up.
pic
Thanks again,
Bread
Bread,
great outcome on a good thread.
Dave,
Thank You as usual for Your input,always valued.
steve sr.
Thanks Steve!
My Blog
