1 members (mick53),
202
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I apologize if this question has previously been answered--I did a quick search and did not uncover any thing.
Any recommendations for a radiator in a Task Force to go with LS motor? I really don't want to spend north of $700 for one either, I am hoping someone has a bolt in for less than $400, but that may be a pipe dream.
If I have to I can fab in a different radiator mount or weld up hard-line radiator tubing or both, but I would rather save the time for doing that for things I can't buy.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you've got a good original, that'd work fine with proper shroud Bill | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I just purchased a Champion radiator. It will be a while until I install it. Reviews I have read have been favorable. http://www.championradiators.com/ | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Thanks for the suggestions, fellas. The price sure is right on those Champions. What do you think of the looks of it, MNSmith? Does it have a fitting for the steam tube of the LS motors?
R-Bo
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | The radiator looks well built. Time will tell. No port for the steam tube although, from what I understand, some guys are tapping in to the water pump or in to the upper radiator hose. If you're handy with a welder, I'm sure you could weld a bung in to the radiator or have a shop do it. | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I have not TIG'ed enough aluminum to be that handy. I would just melt a few holes in a brand-new piece. (For me I get a hole about .5 seconds after I get a puddle to form!!!
I have a new water pump to put on it and will go that route.
Thanks for the info. I think I will go with the Champion since my original is suspect and doesn't have fittings for transmission.
BTW, cool build pics on your Suburban.
R-Bo
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Speedway has generic aluminum model that worked in mine Pick the size closest to what U need and fab it up. Easy in my case and very inexpensive. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | BTW, cool build pics on your Suburban. Thanks! | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | The LS engines do not produce a lot of heat, a stock rad would be fine and would good too (I do not like aluminium rads, they are too shiny for me!).
'57 Chevy Suburban; '70 Chevy Impala.
