4 members (TexasJim50, 1955 1 Series, Otto Skorzeny, RLB), 55 guests, and 1 robot.
Topics128,154
Posts1,056,851
Members48,456
I just bought a new fuel sending unit for my '65 C-10, and I ran into a problem.
For years the wire has been off the inop fuel sender in my truck, and now and then the wire would touch ground and the guage would show full, flutter around and then go back down when the wire broke contact..
I went to install the new unit and the guage now goes from under empty to the empty line and stays there solidly when grounded.
When I lightly brush the contact against a ground it goes all the way over smoothly and then comes back down smoothly.
Any ideas?
Thanks, Mike
The only thing I know for sure is that the sending unit and gas gauge has to match(ohms)...just in case you might want to check that out.. good luck,,Fred
a lot of post on this subject, I made a few my self.might want to do a search within our posts,
Redryder pix
My Hotrod
I fixed the guage!
One of the armature wires had broken, so I disassembled the guage, unwound the wire enough to reach the solder plate and resoldered it.
All works as it should.
Thanks for the input.
Mike
Great.....Fred
Redryder pix
My Hotrod
Junior Member
Junior Member
An almost identical fix works for a very common problem in Dremel Mototools--one of the field coil wires breaking at the little socket where the brush holder/speed control plugs into the stator assmby. The only *trick* to the fix is remembering that these are enameled wires that MUST be scraped clean in order to take solder.
IF YOU DIDN'T TEST IT, IT DOESN'T WORK
