0 members (),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92326 07/14/2005 3:04 AM | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | I just bought a new fuel sending unit for my '65 C-10, and I ran into a problem. For years the wire has been off the inop fuel sender in my truck, and now and then the wire would touch ground and the guage would show full, flutter around and then go back down when the wire broke contact.. I went to install the new unit and the guage now goes from under empty to the empty line and stays there solidly when grounded. When I lightly brush the contact against a ground it goes all the way over smoothly and then comes back down smoothly. Any ideas? Thanks, Mike | | |
#92327 07/14/2005 1:06 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | The only thing I know for sure is that the sending unit and gas gauge has to match(ohms)...just in case you might want to check that out.. good luck,,Fred
a lot of post on this subject, I made a few my self.might want to do a search within our posts, Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92328 07/17/2005 11:00 PM | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | I fixed the guage! One of the armature wires had broken, so I disassembled the guage, unwound the wire enough to reach the solder plate and resoldered it. All works as it should. Thanks for the input. Mike | | |
#92329 07/18/2005 2:30 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#92330 08/28/2005 6:46 AM | Joined: Nov 2004 Posts: 10 Junior Member | | Junior Member Joined: Nov 2004 Posts: 10 | An almost identical fix works for a very common problem in Dremel Mototools--one of the field coil wires breaking at the little socket where the brush holder/speed control plugs into the stator assmby. The only *trick* to the fix is remembering that these are enameled wires that MUST be scraped clean in order to take solder.
IF YOU DIDN'T TEST IT, IT DOESN'T WORK
