3 members (fonz8261, DadsFirstPickup, greenie-reddy), 114 guests, and 4 robots.
Topics128,184
Posts1,057,195
Members48,465
I see that Patricks sells a set out of stainless steel for fairly big bucks. Does anyone supply a regular steel set?
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
I dunno. I bought some 10' lengths of pipe, and some mandrel bends. I cut off the sections of curve I needed, then welded it up. It was cheap and simple.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
1946 1/2-Ton Chevy
Dogface,
Your title is "Fenton headers"
That Chevs of the 40s listing is for a single exhaust pipe/line, for the angle of the 216 exhaust header. They have another listing for the angle of the later 235 header.
You could use the standard exhaust pipe for one of the headers, just be sure the angle of the pipe is the same as the angle on the header.
Local muffler shop?
Dennis
