2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I see that Patricks sells a set out of stainless steel for fairly big bucks. Does anyone supply a regular steel set? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I dunno. I bought some 10' lengths of pipe, and some mandrel bends. I cut off the sections of curve I needed, then welded it up. It was cheap and simple. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Dogface, Your title is "Fenton headers" That Chevs of the 40s listing is for a single exhaust pipe/line, for the angle of the 216 exhaust header. They have another listing for the angle of the later 235 header. You could use the standard exhaust pipe for one of the headers, just be sure the angle of the pipe is the same as the angle on the header. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 |
Dennis -there is nothing stronger than the heart of a volunteer-
