| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#92217 06/24/2005 6:24 PM | Joined: Jan 2003 Posts: 24 Junior Member | | Junior Member Joined: Jan 2003 Posts: 24 | I have a '51 AD 3/4 ton with a new generator, new voltage regulator and a new battery (all 6 volt).
The problem is that the ammeter showed a good charge (about half way between 0 and full charge) up until a few days ago. For a while the ammeter showed that the system was discharging, but now the needle sits almost exactly at 0, showing a little bit of charging at higher RPMs and a little bit of discharging at idle. Turning on the headlights moves the needle to the discharge side.
What should the readings be? What might have happened? What can I do to get the system functioning properly?
Thanks in advance.
Rob | | |
#92218 06/24/2005 10:07 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | This may be normal.Amps are current flow. If the battery is fully charged there is little current flow into it. Turn on the lights & heater. At idle it will show discharge. Acelerate the engine & it should go to charge & settle back to very slight charge. That is normal. Check in back of the amp gauge & make shure the wires are not loose or hot. It would help to hook a voltmeter up to the battery. When you accelerate the engine you should have 6.8 To 7.2 volts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#92219 06/25/2005 9:43 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Just a shot in the dark,I've had regulators go bad early,a couple that didn't work rright from day one. It's a long shot,but just because it's new,doesn't mean it's good. | | |
#92220 06/29/2005 2:51 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If it discharges with the lights on and the motor speed above idle, something has gone wrong, no doubt about it. If you still have your old regulator, you could give it a try to see if that is the problem. | | |
