Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (3800GUY, baldeagle, Wayne67vert), 42 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#92217 06/24/2005 6:24 PM
Junior Member
Junior Member
I have a '51 AD 3/4 ton with a new generator, new voltage regulator and a new battery (all 6 volt).
The problem is that the ammeter showed a good charge (about half way between 0 and full charge) up until a few days ago. For a while the ammeter showed that the system was discharging, but now the needle sits almost exactly at 0, showing a little bit of charging at higher RPMs and a little bit of discharging at idle. Turning on the headlights moves the needle to the discharge side.
What should the readings be? What might have happened? What can I do to get the system functioning properly?
Thanks in advance.
Rob
#92218 06/24/2005 10:07 PM
Riding in the Passing Lane
This may be normal.Amps are current flow. If the battery is fully charged there is little current flow into it. Turn on the lights & heater. At idle it will show discharge. Acelerate the engine & it should go to charge & settle back to very slight charge. That is normal. Check in back of the amp gauge & make shure the wires are not loose or hot. It would help to hook a voltmeter up to the battery. When you accelerate the engine you should have 6.8 To 7.2 volts.
1972 Chevy c10 Cheyenne Super
#92219 06/25/2005 9:43 AM
Just a shot in the dark,I've had regulators go bad early,a couple that didn't work rright from day one. It's a long shot,but just because it's new,doesn't mean it's good.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#92220 06/29/2005 2:51 AM
If it discharges with the lights on and the motor speed above idle, something has gone wrong, no doubt about it. If you still have your old regulator, you could give it a try to see if that is the problem.
1951 1 Ton Completed
