Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Shaffer's1950, Hanks custodian, Otto Skorzeny, homer52, Cletus1950, TUTS 59), 114 guests, and 6 robots.
Topics128,283
Posts1,058,519
Members48,490
I would like to change the entire rear axle on my 51 3100 and keep the original 4 speed. My ? is what or how to seal the rear opening on the trans when changing to an open drivshaft??? I changed (will be) the engine to a 73 250 and kept the sm 420 4 speed it had in the truck originally.
thanks, BILL
I
I Offline
Just find an open driveline SM420 and use it as is or steal the retainer off of it.
ODSS Lawman
ODSS Lawman
You have two options. You can tear your SM420 apart and change the rear housing for an open dirveline setup or swap the whole transmission.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Sweet is making it sound harder than it is.
You only need to change the yoke and rear housing. This can be easily done with the transmission in the truck.
My Blog
ODSS Lawman
ODSS Lawman
Learn something new everyday. Thanks Dave!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
