1 members (wilbur53), 101 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
#92184 06/21/2005 6:00 PM
I just brought home a 56 GMC with the inline 6 that has a 6volt system. I'm looking for tips and what all I need to change out to convert it to a 12 volt. Thanks
#92185 06/22/2005 3:38 AM
This link is in the tech tip section.
12 Volt conversion
#92186 06/22/2005 5:50 AM
Why are you changing to 12 volts? With a little work (less then converting) your 6 volt system will work just fine.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#92187 06/22/2005 6:47 AM
If your upgradeing your radio or puting in modern day features I say ok. If your only doing it to help turn over your engine, I say don't do it. The factory engines turn over just fine with a good grounded 6V system. Cecil......
#92188 06/22/2005 2:22 PM
Thanks guys
I guess i should see if the engine turns first.
#92189 06/22/2005 6:39 PM
Chevy went 12V in 1955. When did GMC?
#92190 06/23/2005 4:57 AM
GMCs with V8s went 12V in 1955. The sixes stayed with 6V for one more year.
#92191 06/23/2005 6:18 AM
Isn't 1956 one more year?
#92192 06/24/2005 4:28 PM
If you want to make life simple order a copy of the Official 12-volt Conversion Guide from Fifth Avenue. The cost is ten dollars post paid. It is a simple step by step guide to doing a 12-volt conversion the right way. It explains what you need to do in simple step by step terms... then also gives you the "why it works that way... so you know how things work and are not doing it just because.... and never knowing why. Take it from the guy who has been then and done that for the past 20 years. Dang...he must be getting old!!
Randy
