1 members (dt235sd),
122
0
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | i guess I had a 216 carb and manifold on my 235, so i put a 235 manifold on and my carb wont fit. a 62 impala 235 carb should be the same right? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Guess your saying the 216 carb doesn't fit on this manifold. You can make it fit by extending the mounting holes, use a saw or abrasive blade. I've seen lots of 216 carbs done this way but of course the actual 235 carb would be best. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | i dont wanna hacl up a good 216 carb.. And I assume that the bolt pattern is the same, but i wanted to make sure the linkage should be as well? I know there are some diffrences in certin things 59-62 like tranny boss, ect.. | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | I would guess the 216 would have a manual choke and the 235 Impala would have an automatic choke. You can probably still buy a kit at the local FLAPS to convert it to a manual choke. Jim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will need thge air cleaner to go with the 62 carb. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | So I got the impala carb and it doesn't have the vac advan on the base near the throttle shaft but there is a tube sticking out the side with a half inch of rubber hose. Is that where my vac advance line goes? Or onthe choke coil cover there is a pipe threading that looks simaler to the vac advan connection that's on my 216 Rochester b. the choke coil cover is metal I thought there were usually plastic . Lol I though it wouldent be a big diff. Now I'm wondering if I should elongate that one... Thanks for your help | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What about useing the top of the 216 carb on the 235 carb. Change the main jet & power valve spring. Then you will have your manual choke. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | But then where does the vac advance hook up to? Can I combine a b and bc? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can hook it to that tube. It will probably give you full advance at idle but thats OK. The top part is all you will want to change. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That is for the automatic chock. There should be an outlet on the other side for the vacuum advance. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | there isnt a vac ad line on this 235 base. the 216 has it next to the mixture screw. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have never seen a model B that did not have a vacuum advance port. Can you post a pic of that side of the carb?
See the USA in your vintage Chevrolet! My Blog | | |
