2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
After reading several older threads I think I need to install an ignition resistor between ignition and coil, but what do the experts think?
My setup is:
'52 1/2 ton
'62 261
12V Alternator
HEI distributor from Tom Langdon
12V coil from Tom Langdon
Foot starter with original 6V starter
My conclusion is that I might be able to operate ok without the resistor, but being the conservative that I am, it wouldn't hurt to install it. Appreciate your thoughts.
shoeless
I'm not an expert, but I'm pretty sure you
will need a ballast resistor. You might check
your coil box and see if its marked if a
resistor is required. I had bought one that
already had it intergreated into the coil.
You have an HEI distributor - electronic ignition. No ballast resistor needed or wanted!
Ballast resistors are for 12 volt ignitions with contact points.
Gord
1954 1/2 ton 235 4 speed
I have a 46 and converting to 12 volt (battery, alt, and HEI distributor (via Tech pages). Any major wiring concens, considerations, or digressions from the norm?
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
cavebull,
WOW, hooking onto a two year old thread..I thought my eyes went nuts. smile
I guess I would say there are no major concerns if you know what you are doing and can do it.
If you have indeed studied the Tech Tips on this subject, and maybe done a search in this forum on the changeover, it should be straight forward.
Remember, you can start a new thread by clicking on the "Post New Topic" button.
Stuart
Automarc,
I know it is an old thread just wanted someone to know I am in deed searching out a subject before porting, ha!
cavebull
when converting to HEI from a points distributor, you should replace the power wire with a non-resistor wire.
Another quality post.
Real Trucks Rattle
