3 members (Hanks custodian, wilbur53, 1 invisible), 110 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
#919600 02/13/2013 2:42 PM
i guess I had a 216 carb and manifold on my 235, so i put a 235 manifold on and my carb wont fit. a 62 impala 235 carb should be the same right?
Guess your saying the 216 carb doesn't fit on this manifold. You can make it fit by extending the mounting holes, use a saw or abrasive blade. I've seen lots of 216 carbs done this way but of course the actual 235 carb would be best.
1946 1/2-Ton Chevy
i dont wanna hacl up a good 216 carb.. And I assume that the bolt pattern is the same, but i wanted to make sure the linkage should be as well? I know there are some diffrences in certin things 59-62 like tranny boss, ect..
J M Offline
I would guess the 216 would have a manual choke and the 235 Impala would have an automatic choke. You can probably still buy a kit at the local FLAPS to convert it to a manual choke.
Jim
Riding in the Passing Lane
You will need thge air cleaner to go with the 62 carb.
1972 Chevy c10 Cheyenne Super
So I got the impala carb and it doesn't have the vac advan on the base near the throttle shaft but there is a tube sticking out the side with a half inch of rubber hose. Is that where my vac advance line goes? Or onthe choke coil cover there is a pipe threading that looks simaler to the vac advan connection that's on my 216 Rochester b. the choke coil cover is metal I thought there were usually plastic . Lol I though it wouldent be a big diff. Now I'm wondering if I should elongate that one... Thanks for your help
What about useing the top of the 216 carb on the 235 carb. Change the main jet & power valve spring. Then you will have your manual choke.
But then where does the vac advance hook up to? Can I combine a b and bc?
You can hook it to that tube. It will probably give you full advance at idle but thats OK. The top part is all you will want to change.
so it looks like it fits like this.
http://i1095.photobucket.com/albums/i465/bigdrewvigil/photo255_zps5b75d4a6.jpg
235 ac base with 216 m.c carb. can i hook my val like to this ?
That is for the automatic chock. There should be an outlet on the other side for the vacuum advance.
there isnt a vac ad line on this 235 base. the 216 has it next to the mixture screw.
I have never seen a model B that did not have a vacuum advance port.
Can you post a pic of that side of the carb?
My Blog
