7 members (Ponchogl, Otto Skorzeny, GMCJammer51, WICruiser, Southerntruck, 78buckshot, Napco Man), 139 guests, and 1 robot.
Topics128,105
Posts1,056,545
Members48,448
I have a 1954 Chev 3100 and do not have the front fender braces--I need to know if they are the same for the 47-53 trucks? Any help would be appreciated--thanks
Y
Y Offline
Yes, all the same 47 thru 54
Thanks! Now I just have to find them
Post a Want Ad in the Swap Meet for the fender braces, or buy them from a vendor: front fender-to-firewall braces or lower front fender brace (other venders in the Links section also sell both pairs of braces in regular steel and stainless steel).
Oh I am sorry--the braces I am refering to attach to the radiator core support and and attach on the outer fender lip--are those the same for 1947-1954?
Mike, your PM box is over the limit so I can't leave a message.
However, we need to know if what your looking for is the round rod braces or the big fender brace that attaches to the radiator support piece..I call it the horseshoe.
Good morning--it is the "horseshoe" braces that attached to the radiator support...when we got the truck the front clip was off and the braces were no where to be found-also I have never had a PM so I will have to find out why it says it is over the limit--Thanks again! Mike
Are you referring to the "braces"/"side-arms" that are welded to the radiator frame?
guys,
Mike is talking about the fender braces that bolt thru the fender into the radiator support and arch across the fender,behind the headlite pod and attach to the outer lip of the fender.
And Mike yes you should be able to use 47-53 braces if you can get them.
Should be the same for the entire A-D run.
regards,
steve sr.
Thanks you very much!
Thanks, Steve - the heavy, channeled brace that goes under/inside the top surface of the fender - duh/doh
Group 8.141 - left and right - same 47-55st?
Mike,
Your quite welcome.
Tim no worries,musta been one of those Sr.moments,lookin foward to Friday.
Lord knows I LUVS Me a Bunch a Fridays.
regards
steve sr.
