0 members (),
37
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91961 01/19/2005 6:26 AM | Joined: Jan 2004 Posts: 58 Member | | Member Joined: Jan 2004 Posts: 58 | due to having a 235 12v with a 6v flywheel and key start. I find myself having to purchase a 6v starter w/ seleniod from a 1949 chevy sedan, automatic. What can I expect to happen when I connect it. Thanks Jorge | | |
#91962 01/19/2005 2:59 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Well are you hooking it up to 12 volts? If yes the starter will be fine but (I am not sure about this part) I think you will need to put a resistor in line to the solinoid. 12 volts may burn it up. I am sure the some of my fellow bolters will tell me if I am full of it or not.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#91963 01/19/2005 8:37 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Why don't you convert it to a 12V flywheel? They are not that hard to come by.
You may need to use a 12V solenoid with the 6 volt starter, which may require some creativity, or convert back to a 6V foot stomp starter, which can be run on 12V with impunity as long as you don't allow it to overheat by cranking too long.
