4 members (Hotrod Lincoln, Simon1954, Otto Skorzeny, klhansen), 40 guests, and 9 robots.
Topics128,012
Posts1,055,315
Members48,419
#91961 01/19/2005 6:26 AM
due to having a 235 12v with a 6v flywheel and key start. I find myself having to purchase a 6v starter w/ seleniod from a 1949 chevy sedan, automatic. What can I expect to happen when I connect it. Thanks Jorge
1950 3100
1980 "Vette"
2005 Mustang GT
http://community.webshots.com/user/jlr1516
#91962 01/19/2005 2:59 PM
Well are you hooking it up to 12 volts? If yes the starter will be fine but (I am not sure about this part) I think you will need to put a resistor in line to the solinoid. 12 volts may burn it up. I am sure the some of my fellow bolters will tell me if I am full of it or not.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#91963 01/19/2005 8:37 PM
Why don't you convert it to a 12V flywheel? They are not that hard to come by.
You may need to use a 12V solenoid with the 6 volt starter, which may require some creativity, or convert back to a 6V foot stomp starter, which can be run on 12V with impunity as long as you don't allow it to overheat by cranking too long.
Paint & Body Shop moderator
