10 members (1955 1 Series, 3800GUY, UtahYork, Hawkman, Maybellene, 5 Window 9434, 39Master85, 52Carl, Hotrod Lincoln, 1 invisible),
82
Mod | | | Forums66 Topics128,089 Posts1,056,355 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 7 New Guy | | New Guy Joined: Feb 2013 Posts: 7 | I have a 1954 Chev 3100 and do not have the front fender braces--I need to know if they are the same for the 47-53 trucks? Any help would be appreciated--thanks | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Yes, all the same 47 thru 54 | | | | | Joined: Feb 2013 Posts: 7 New Guy | | New Guy Joined: Feb 2013 Posts: 7 | Thanks! Now I just have to find them | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Post a Want Ad in the Swap Meet for the fender braces, or buy them from a vendor: front fender-to-firewall braces or lower front fender brace (other venders in the Links section also sell both pairs of braces in regular steel and stainless steel). | | | | | Joined: Feb 2013 Posts: 7 New Guy | | New Guy Joined: Feb 2013 Posts: 7 | Oh I am sorry--the braces I am refering to attach to the radiator core support and and attach on the outer fender lip--are those the same for 1947-1954? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Mike, your PM box is over the limit so I can't leave a message. However, we need to know if what your looking for is the round rod braces or the big fender brace that attaches to the radiator support piece..I call it the horseshoe. | | | | | Joined: Feb 2013 Posts: 7 New Guy | | New Guy Joined: Feb 2013 Posts: 7 | Good morning--it is the "horseshoe" braces that attached to the radiator support...when we got the truck the front clip was off and the braces were no where to be found-also I have never had a PM so I will have to find out why it says it is over the limit--Thanks again! Mike | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are you referring to the "braces"/"side-arms" that are welded to the radiator frame? | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | guys, Mike is talking about the fender braces that bolt thru the fender into the radiator support and arch across the fender,behind the headlite pod and attach to the outer lip of the fender. And Mike yes you should be able to use 47-53 braces if you can get them. Should be the same for the entire A-D run. regards, steve sr.
| | | | | Joined: Feb 2013 Posts: 7 New Guy | | New Guy Joined: Feb 2013 Posts: 7 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Steve - the heavy, channeled brace that goes under/inside the top surface of the fender - duh/doh Group 8.141 - left and right - same 47-55st? | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Mike, Your quite welcome. Tim no worries,musta been one of those Sr.moments,lookin foward to Friday. Lord knows I LUVS Me a Bunch a Fridays. regards steve sr.
