Scott Ward's1948 1.5-Ton Loadmaster |
21 March 2007 Update
Here's a picture of one of my Big Bolts hard at work! I usually haul wood with this one. This load, however, consisted mostly of a 1964 and a 1966 C10 truck, minus the engines and transmissions. There's two full frames, cabs, front clips, front suspensions and a rear-end set up on there. Added to that are some leftovers from several other projects. The load ended up weighing 3000 pounds.
That red '48 is still a 235 ci powered truck with a 4 speed and a hydraulic dump bed. Getting the load there (about 20-25 miles from home) was a little nerve racking just hoping it would all stay put. The drive home after dark with 6-volt headlights was about as bad. ![]()
Scott Ward
"48bigtrucks"
Stovebolter # 4443
Center Point, Iowa
Yes, Scott does have a few to old trucks here : -- a 1955.1 Chevy 6500 series with an additional 2 foot frame stretch; a 1963 Chevy K-20; a 1948 Chevy 1.5-ton Loadmaster; another 1948 Chevy 1.5-ton Loadmaster (double your pleasure
); a 1951 Chevy 1.5-ton Dump Truck; and acquired from a Stovebolter "Bubba," the 1955 1st Series Chevy 5700 COE; a 1954 Chevy 6500 2-Ton; a 1953 and a 1956 Ford F800 -- something to plow with (and I bet he has others
) ~~ Editor
06 April 2004
As my forum name (48bigtrucks) indicates, I have two 1948 trucks (Check the other one, too -- Editor).
This is my second 1948 1 1/2-ton Loadmaster. This one is bone stock original.
A retired farmer had it in his barn when I found it. It was only used in the fall to haul grain in from the fields. It has 18K original miles on it. He sold it to me for $750 and I drove it home. The only thing I've done to it since is a complete brake overhaul, changed the intake/exhaust gaskets, replaced the rest of the exhaust and service all of the fluids and filters.
Thanks for posting my trucks. I'm especially proud of this find.
Scott Ward
"48bigtrucks"
Stovebolter # 4443
Center Point, Iowa
Besides the two '48's, in March 2006, Scott got himself a '55 Chevy 1st Series 5700 COE from a fellow Stovebolter. In November, Scott added a 1963 Chevy K20 to the Gallery. And don't forget to check the Alternative Gallery for his stuff. This man likes to work!
~~ Editor
| No parts of this site, its contents, photos or graphics may be used without permission. |
