6 members (55shaker, Otto Skorzeny, Gray_Ghost, Hush, 52Carl, JW51), 155 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#9177 07/22/2004 12:29 AM
U
Junior Member
Junior Member
U Offline
:confused: Please help me! I have a 49 1 ton Chevy, wanting to put a Pacer IFS under it, can it be done for a 1 ton truck, or should I just rebuild my original front suspension? I have replaced the tie-rod ends, and rebuilt the drag link. Everything seems ok, but need some advice on what may be best. Thanks.
#9178 07/22/2004 1:31 AM
If you are going to use your 1 ton as a 1 ton, I would strongly suggest rebuilding the original. Those light weight IFS set-ups are for hotrods that never carry a load. Besides, who would want "Pacer" parts on their A.D. truck anyway.
Just my opinion, there will be many more to follow,
Scott
P.S. Welcome to the Stovebolt, I'm a relative new comer also.
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#9179 07/22/2004 3:03 AM
Junior Member
Junior Member
Swabby,
As suggested above, if you are restoring a 1 ton truck, you need to keep 1 ton running gear under her. I have a 51 3604 truck with bias ply 7.50 16 tires and the truck drives fine. If I feel the need for speed and a comfortable ride, a one ton truck is not my first choice.
1951 Chevy 3600, 1996 Yukon, 2000 Road King
It is easy to take liberty for granted, when you have never had it taken from you.
http://www.stovebolt.com/gallery.htm
#9180 07/22/2004 3:08 AM
What are you trying to accomplish? Better ride? Better brakes? A hot rod?
I think I'd consider a 70's or 80's Chevy or GMC 3/4-ton or 1-ton pickup IFS in any case.
If you go ahead please contact me at my personal email address.
#9181 07/22/2004 6:13 AM
Anonymous
Unregistered
Anonymous
Unregistered
Alright - another Portlander! Straight axle up front will suit you just fine and an 8 lug disk brake setup is relatively easy to fab as well.
I have a 4400 that has excellent road manners and see no need to change it. If you take the time to do king pins, tie rod ends and draglink ends . . . AND if you really go all out go with radials - it will steer like a dream.
#9182 07/22/2004 2:01 PM
Here is something else to think about. If you happen to find a pacer front end you will need to replace bushing and tie rods and whatever else needs to be replaced due to the fact that it has sat for almost 20 years. By the time you do that you will have exceeded the cost of fixing up your original front end.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#9183 07/22/2004 4:19 PM
U
Junior Member
Junior Member
U Offline
Hey thanks for the overwhelming responses! I've been working on my truck since 1998, when I bought it for 180.00, I believe that I'll rebuild the current front end, but this bring to mind another question or two. I would like to get a better highway speed out of the rearend, Jim Carters has a ring and pinion gear set for the 5.14 rearend changes to 3.90 or something like it, has anyone had any experience with these? and should I stay with the original 17" wheels?
#9184 07/23/2004 2:48 AM
Sorry, I have to put a good word in for the Pacer front end if you are considering getting away from the stock front end. It works fine at least on my 1/2 ton. You may have to put in springs that are stiffer (spring rate). All the parts can still be had for the Pacer front end unit. The Pacer was a goofy car but that front crossmember is plenty strong and heavy. Fits in relatively easily and will go in a lot quicker than a front frame graft. People put in stuff from a Mustang so what is wrong with using a Pacer front end? Usnavy, I took pics when I installed mine, let me know if you are interested.
#9185 07/26/2004 4:31 PM
Quote
really? how? i have a 59 1-ton, and i want to keep the straight axle, but put some power disc brakes on it. my main problem i see, is fabbing the brakets for the calipers.
'59 Chevy 1-ton
'03 **** Lightning
'96 Kawasaki 1100 zxi
#9186 07/26/2004 5:06 PM
RearEnd:
The 3.90 gear set only fits in the more modern carrier, I think for the years 67 to 71, but the range of years may be larger. The carrier from those years is also a straight bolt in for the older 1 Ton.
8 Lug front Disk:
I think there is a web site somewhere where somebody shows this. Any leads ?
1951 1 Ton Completed
#9187 07/26/2004 5:18 PM
There used to be a webpage by a fellow named John Dorsey...1 ton AD panel truck with the front disc conversion he did himself. I just checked over on www.chevytrucks.org and unfortunately, the link to his page is dead or needs to be updated, or something. frown
I think Mr. Dorsey used to come by here occasionally, can't remember for sure. Maybe someone here is acquainted with him? :confused:
Hope you can find something with this...
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#9188 07/26/2004 8:22 PM
I remember seeing that 1-ton panel disk brake conversion. Because things like that seem to disappear I've taken to saving them for future reference. Unfortunately I didn't get that one....
I'm thinking about converting my '52 6400 to 8-lug disk brakes. Anyone tried that?
#9189 07/27/2004 4:45 AM
All I know is pacers are good for one thing and thats falling apart. How many of those do you see driving still?? My buddy had one he bought for two hundred bucks and it was a piece. My two cents. Jess grin
1951 3100
#9190 07/27/2004 8:45 PM
I'll throw in one more concern that involves shocks & coil springs. You need to find out what your trucks front-end weighs (provided in various reference manuals)and then get the apropriately weighted springs and shocks to maintain the correct shock rebound & ride height. For instance,my '52 Burb front end weighs 1835lbs...I need 1900 lb front coil springs.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
