2 members (RLB, 1 invisible), 182 guests, and 1 robot.
Topics128,079
Posts1,056,058
Members48,433
#917167 02/04/2013 12:04 PM
I
I Offline
Does the year make a difference when ordering a master rebuild kit for a 292?
My casting number is 8994256 which is a 64-77 but I have seen specific years called out on some rebuild kits.
Also, any recommendations on kits? Are any brands better than others?
I would be as specific as possible on the year selection only because you want to make sure it's complete as possible. Personally, I use NAPA over mail order.
Drew
I
I Offline
Is there a way of knowing the exact year? Stamp behind the distributor has FO302TGA
Riding in the Passing Lane
If its a rochester B model the kits are pretty much the same 61 up to 67. If you have a Monojet 68 up the number is stamped vertically on the fuel bowl side. A parts nan can get the right kit from this number. The number will start with 7 or 17. Get the kit from Carquest, Napa, or a Delco.
1972 Chevy c10 Cheyenne Super
I think InMy40s is talking about rebuilding the engine rather than the carb!
Les
