1 members (Hotrod Lincoln),
105
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I just plainly don't like the step plates most vendors carry. I just don' like the "turn up" on them and want to make my own. I like the thin Diamond Plate stuff but WITHOUT the diamond on it. Back sometime ago a bolter here had used some other stuff and rounded his corners which, to me, looked good. I think it was some kind of polished aluminum or BRUSHED aluminum.
I checked at Lowes today and they have the bright diamond plate 12x24 ($30) but I don't want the diamonds.
Anyone know where I can get some "brushed" brite stuff or other idea's that you have used?...Thank You
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | piece of satin finish stainless? I'd think any smooth aluminum would show scratches pretty easy .... the 'turn up' is for boot scraping, not much use if you're not using it out in the fields  Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, yes its for my panel. I have looked at those you posted a link to and almost ordered them on an order a week or so ago. I'm not cheap by any means but $150 for both sides is a killer.
...I also plan to "try something" that most will probably think it won't work but hey, I like trying things. I do not want to drill holes in the running boards so I've decided to put some strips of 3-M weatherstip material on top of the running board ribs and then lay the step plate on top of it and press it down. That box of 3-M stuff I have is pretty darn "sticky" and I think it will hold up under the plats real good. If I want to I can always change the plates...If I can't find what I'm looking for I may go ahead and use the diamond plate just to have something there and change it later. I'm thinking cut it and then round the corners.
Dang it, if I could recall who's truck, here on stovebolt, I'd be set. In fact its where I got the idea. It looked nice and trim. I also "read once" a simple way to make a plate looked "brushed" but its in a box somewhere since I retired and we moved!!!
I'll hijack my own thread here. Where do you get the shiny stuff rodders put on the firewall and looks like a mirror? That is SORT of what I'm looking for....but I've seen it "brushed" but never thought to ask anyone. I guess maybe I'll have to wait till cruise season and ask someone who has it.
Hate to make this post so long but maybe you understand better?? Thanks for being patience with me guys! | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I would think that the step plate would be slippery as heck without the diamond plate (traction). But it would look coooooooool !!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Alvin,
I think that price for the original-style step plates is for the pair. I like your idea for using adhesive.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'll keep you posted guys. Right now I'm working with what I believe to be a rearend problem...but then I get several things going at one time. Just depends on which way I'm traveling!!
Oh,Tim, I looked at that price but it said "1". I'll double check it may have been "1" pair. If so, that may work? | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I read once how to make a shiny plate looked brushed. Don't remember if it was stainless or not, but it sticks in my mind that it was. They took the piece they wanted to "brush" and clamped it to a workbench top with a straight edge. Then they took a sanding block loaded with fairly coarse sandpaper and simply pushed it back and forth along the straight-edge (so the brush marks were parallel) Then they moved the straight-edge and re-clamped it and finished the sanding.
I've never tried it, but is seems pretty easy and the sanding might give just a bit of "grip" when stepping on it.
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Craig, I remember the article as being similar to what you saying. I read it back around '98, or close, and it seemed a type of brush was used and "center points" marked on the metal and then the brushed effect was done in the drill press. I have some pretty dang stiff brushes, say like 1", that would do the trick. Heck, I may try it on a spare piece of 18 guage metal I have..... but I'd love to find it pre-fabed.
I'll keep listening, and looking. It'll come up somewhere! Thanks for everyone's comments. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Chris, what you referred to is what I'm somewhat trying to achieve but not necessarily that "fancy".
I also don't really care for the "bright" work as I think a more "semi-dull" would suit my panel more. I'm on the hunt and I know what I'll get there "sooner or later".Since I plan to mount it without screws I may go ahead temporarily with some diamond plate to protect the running boards until cruise season. I'll probably find lots of what I'm looking for them and leads to where to obtain it. Thankd for all your replies fellows, maybe I can help you someday. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I looked and found three patterns of textured plate at 'McMaster-Carr'. Weave, diamond, and tread. It comes in at around $13.00 for a 12"x12" aluminum piece. I think the weave would look good. That part number is #9058k11 in 0.032" thickness. I use the 3-m tape trick on polished 1/2" sst half round bar I put on my slick running boards. Been there four years and still going strong. Let us know what you think.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hi Alvin....you can get Stainless steel in a variety of thickneses, and finishes from mirror polished to heavy brushed. I kinda like your idea of the " engine turned " finish - would look pretty sharp and not seen every day. Only issue with stainless is its really hard on sawblades and drillbits. You might try a restaurant supply place - maybe they have a few cutoffs laying around ?
| | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | Alvin, I have dealt with Acme Metal near where I live. Here is their website: http://www.acmeindustrialsurplus.com/They are surplus dealers. If you are willing to do some fab work, they will most likely have what you want. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks for the tips guys. Bruce, I agree with you about being a little hard to work with. I have some metal blades for my band saw but luckily for me I have a good friend that runs a machine shop just 2 or 3 miles from my house. Buddy has done a lot of work for me at times and in his works "bring in on, I can drill it, weld it...or mess it up". He's a good guy. I now have several options. I'll take a look and let you guys know what I do. Oh, on one site I liked the "weave" piece but not sure....yet! | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | you could use 1/8 stainless cut it like you want. then hit it with a 36 grit flapper wheel about 3/4"apart to make a nice pattern . then use comercial grade velcrow to mount it to your running boards | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Strips, if you must.
| | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | I vote strips unless you can cut out the Chevy bowtie from the solid one. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Wayne, I've certainly thought about cutting out a bowtie and actually use it for the step tread.... I have enough material left so I may fool around with it to see how it looks before I glue them down permanently.
Anymnore opinions? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'd go for the strips, I bet they stay adhered longer. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Now I want to see a bow tie pattern... out of the strips
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | How about using spray on bed liner material? I've got it in my 2001 Silverado and it still looks good and washes off easy. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I prefere the striped look, over the solid piece, JMO.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Mar 2005 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 31 | Alvin Get some skate board tape well work great | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks guys...... CASO, I was actually thinking about making the bowtie a solid piece out of the meterial. I think I mentioned above I have enough material to experiment.....for $2.95 what the heck, eh. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I was just pulling your leg... I thought your idea of the solid pattern is cool but it just hides too much of that nice paint!
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Well, I still haven't made up my mind. A fellow bolter and I had a phone conversation today and he had a couple neat suggestions. one was to find a skateboard supply place and maybe look at the strips they use on them for "non skid". It is also adhesive backed and sticks like glue. (I like good peel and stick)!! Another idea was perhaps check out the marine supply place for boats. They have some pretty tough "stiprs" that stick good and do well around water!! I've got to do some some checking. Whew, look what a simple question has turned into  .....anther learning curve! Thanks, Steve, and I'll keep ya'll posted. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Alvin, fer Gawd's sake man, how long have you had your truck???? Do what I do. Step OVER the running board and directly into the cab. You don't need no stinkin' runnin' board protection, man.  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Paul, ya gotta take into account Alvin's age, he taint as flexable as he used to be. He's into the "old age shuffle" and has to take small steps now days. Denny G
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Paul, I can't help but laugh at ya... that is exactly what I do in the 37, even my little short wife can do it... but the panel, now thats a truck of a different color  Victoria slmost needs a step ladder. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Well if you're really anal - you can set a piece of rubber tool tray liner on your running boards to enter and exit the truck, then remove the rubber and put a "NO STEP" sign on them to keep the spectators off. > NO STEP> Yep, I really do it!
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | > Yep, I really do it! Lonnie, you just have to show off that ribbon, don't you!
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | [quote=Achipmunk] one was to find a skateboard supply place and maybe look at the strips they use on them for "non skid". It is also adhesive backed and sticks like glue. (I like good peel and stick)!!
Alvin..............I've purchased that self adhesive, non-slip strip from an Industrial Supply place in the past. We used it for a non-slip walk path across a metal building roof. Only issue I see, is that it's pretty thin - soles of your shoes would still impact with the painted areas in between. | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I'm sure Lowes has that shelf adhesive tape in the flooring dept.we call it lick and stick.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bruce, advice well taken. We HAD Grainger locally until about a year go. I still have two place in my home town, Gaffney, which is about 20 miles from me. I'll visit them sometime next week. In the meantime,goneagain, I will make yet another trip to Lowes. As much as I hate going in there I'm learning my way around  ...and Bruce, your right about the thickness. I want it thick enough but I don't like the big step plates ect. If all else fails I'll put the rubber strips on as shown in an earlier post. This just goes to show how many options are out there if we really look and ask questions. Thanks fellows. | | |
