4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#917182 02/04/2013 12:43 PM
Is the only fuel filter on a 1966 C10 (with fuel tank behind the seat) on the carburetor inlet?
Cougar #917197 02/04/2013 2:41 PM
Riding in the Passing Lane
Yes, unless someone has put an inline filter on it. I recomend an in line filter between the gas tank & pump.
1972 Chevy c10 Cheyenne Super
If it is on the suction side of the pump it has to have very low resistance to flow I would think. Any inline filter you suggest?
Cougar #917277 02/04/2013 8:07 PM
I used a spin-on canister style on my '65.
Jegs P/N 410-HPG1
http://i645.photobucket.com/albums/...%20Photos%20Oct%202009/2009_10200008.jpg
Cougar #917398 02/05/2013 10:54 AM
I don't know about Chevy in 1966, but my 1960 GMC came with a factory installed canister filter mounted on the passenger side frame rail just below the seat. You might check there to see if Chevy followed this practice.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Hot Rod John #917670 02/06/2013 7:40 AM
The OEM style was the spin-on can - WITH the filter cart. inside (not quite spin on style). On the GMC's, it was located under the passinger seat area, bolted to the frame. I'll assume Chevy's of the same years were in the same?
Jegs P/N 410-HPG1
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Cougar #917676 02/06/2013 7:57 AM
All I've ever seen on Chevys were the one in the carb, and the screen on the inlet in the tank. The GMC was $49 more, remember.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Cougar #917687 02/06/2013 8:27 AM
The only fuel filters I have found even for the GMC that are not in the carb inlet are in a glass bowl which I don't want under the truck.
Cougar #917704 02/06/2013 10:17 AM
Crusing in the Passing Lane
My 65 Chevy C30 camper has a spin on filter on the right frame rail for the auxiliary tank. Stone filter in the carb.
Currently cruising
in the Passing Lane
Rest in Peace
