| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 27 New Guy | | New Guy Joined: Nov 2012 Posts: 27 | Is the only fuel filter on a 1966 C10 (with fuel tank behind the seat) on the carburetor inlet? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes, unless someone has put an inline filter on it. I recomend an in line filter between the gas tank & pump. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2012 Posts: 27 New Guy | | New Guy Joined: Nov 2012 Posts: 27 | If it is on the suction side of the pump it has to have very low resistance to flow I would think. Any inline filter you suggest? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | I don't know about Chevy in 1966, but my 1960 GMC came with a factory installed canister filter mounted on the passenger side frame rail just below the seat. You might check there to see if Chevy followed this practice. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | The OEM style was the spin-on can - WITH the filter cart. inside (not quite spin on style). On the GMC's, it was located under the passinger seat area, bolted to the frame. I'll assume Chevy's of the same years were in the same? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | All I've ever seen on Chevys were the one in the carb, and the screen on the inlet in the tank. The GMC was $49 more, remember. | | | | | Joined: Nov 2012 Posts: 27 New Guy | | New Guy Joined: Nov 2012 Posts: 27 | The only fuel filters I have found even for the GMC that are not in the carb inlet are in a glass bowl which I don't want under the truck. | | | | | Joined: Feb 2010 Posts: 82 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Feb 2010 Posts: 82 | My 65 Chevy C30 camper has a spin on filter on the right frame rail for the auxiliary tank. Stone filter in the carb. | | |
