| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Does the year make a difference when ordering a master rebuild kit for a 292?
My casting number is 8994256 which is a 64-77 but I have seen specific years called out on some rebuild kits.
Also, any recommendations on kits? Are any brands better than others? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I would be as specific as possible on the year selection only because you want to make sure it's complete as possible. Personally, I use NAPA over mail order.
Drew
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Is there a way of knowing the exact year? Stamp behind the distributor has FO302TGA | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If its a rochester B model the kits are pretty much the same 61 up to 67. If you have a Monojet 68 up the number is stamped vertically on the fuel bowl side. A parts nan can get the right kit from this number. The number will start with 7 or 17. Get the kit from Carquest, Napa, or a Delco. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | I think InMy40s is talking about rebuilding the engine rather than the carb!
Les | | |
