2 members (Guitplayer, JW51),
148
Mod | | | Forums66 Topics128,087 Posts1,056,114 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Anybody know here you can buy these things for a 56 3100? I have tried all the usual suspects with no luck, Filling Station has them listed but on backorder and no ETA. Apparently they are different from the 55 1st on back arms which are available like everywhere. None on EBay. Thanks,
Dale | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've never seen the transmission arms reproduced for any of the TF years [55.2-57 are the same], you'll be looking for used, a post in the parts wanted would eventually find some
Bill | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Hi Bill,
I talked to the Filling Station guy again after your post and he indicated he does have a vendor for reproduced 55 2nd up arms, and they do have a stock part number and entry on their parts list, but no surprise they are on back order - probably very few requests. For now I'll just go to parts wanted and see if something turns up. Thanks --
Dale
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Never say never.....thanks Dale, learn something new everyday....on The Bolt!!! | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Dale, I bought arms for my 59 from bowtie bits, they were sued but are still working. Call them and see, maybe they can help.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 |
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Yeah - I figured that was what you meant Tommy -- tried BTB - no luck so just put a line on the parts wanted forum -- thanks for your tip ---
Dale | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Carter and American Classic also both have used parts, might check with them
Bill | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Took a little while, but Jim Carter came up with a used arm from their used parts department. Got a call from them saying they thought they had one. Called Arnold (their used parts guru) back - he went through his bins of transmission arms and found the one marked "L" for left and numbers (two sets of numbers, one on each end of the arm) all matched. Little bitty part of a truck, but hard to find, and thanks to Jim Carter and Arnold, their used parts guy, and thanks for all the tips and offers of help from this family as well. Back in service.
Dale | | |
