3 members (Gray_Ghost, Otto Skorzeny, Stovebolt48), 29 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#917057 02/03/2013 10:42 PM
I just got my "48" cab back from the body shop and putting it all together. I installed a rubber gasket on the front top cowl vent and it works perfect, closes flush. The drivers side no so much. This gasket came in foam. I glued it to the cab and installed the vent. If I hold the inside handle closed the vent still is not quite flush. The gasket wants to push it out. If I push on the vent from the outide it will close but will not stay closed, foam pushes it open. There also does not seem to be any way to hold that vent closed. The handle has no catch to keet it in place. What could I have wrong.
If you never tell a lie, you never need to remember what you said.
sounds like a loose hinge/cam point just reading but I don't know that era truck at all. what if you close it tight and run a light heat gun over the foam for a few cycles and see if it 'sets up' a little?... again just wondering no experience.
Give me ambiguity
or give me something else
Your ’48 should look like this Bart:
http://www.pbase.com/dennygraham/image/148636641
You can see the notch in the slot, which is what holds the vent door in the closed
position.
Here is a ’50 outside shot showing the foam seal in place:
http://www.pbase.com/dennygraham/image/148636643
It sits flush with the raised metal edge of the grove.
And here is the inside slot, the handle and slot are a little different after ’49 and look like
this one:
http://www.pbase.com/dennygraham/image/148636645
You may have to give it a little time before the foam seats but still you should be able to
latch the handle an keep the door closed.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Mine has the inside plate that your first picture shows and it was installed with the slot to the firewall side. Not that much of a slot on mine. I may have to file it some but now I see how it should work. Thanks for the reply. I do have my foam gasket on just like you show.
Might help to post a picture Bart, you know what they say, a picture says a thousand word.
It makes no sense to put the notch toward the front, are you sure someone didn't weld a
new plate in place of the old one? I can't imagine any reason why or how they would want
to do that but you never know.
DG
Denny G
Sandwich, IL
My inside vent plate looks like this. Like I said, no notch but I should be able the file a notch into this inside plate and that should hold the vent shut.
The early vent application can come with a notch and without. Here is a clear view of the early style vent with notch.
http://www.flickr.com/photos/advance-design_parts_co/8129342725/in/set-72157631868452754
And here is the early version without the notch.
http://www.flickr.com/photos/advance-design_parts_co/8129356256/in/set-72157631868452754
I believe this was a running change most likely to address the issue you describe.
Here you can see the significant difference in handles when the interior plates and springs were eliminated.
http://www.flickr.com/photos/advance-design_parts_co/8129367190/in/set-72157631868452754/
Thanks for completing the picture Brad, I snatched that image
from you some time ago. Did you document what years those
vents, plates and handles came out of???
I think you're right on the money about the very early AD not
having a notch, and them adding it when the spring didn't keep
it closed. I would have thought it was by the end of the 1947
run after they had a bunch of them back to the dealer with complaints.
Are you sure about the year of your truck Bart, i.e., 1948????
Denny Graham
Sandwich, IL
Denny G
Denny G
Sandwich, IL
My '48 has the notch.
Why not try to find a plate with the notch?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Early plate w/o the notch is 1947 to late 48 as near as I can tell by 49 they were using the notch. Denny the picture you posted was from an early 49' 5-window Deluxe 3100 I owned. Very original and well-optioned truck. I agree this was a running fix I am sure based on customer complaints.
Ha! I was rummaging through a parts drawer the other day and came across a plate. Yours for shipping, Bart.
This is why I love this site!
Good people here, every day!
Thanks for the offer on the plate but I just filed a notch into my plate Only damage was a little lost paint. First scratch had to come sometime. This did solve the problem, see the vent now. I cant say I am liking the foam gasket but may be able to do something with that. I think I will change it to a rubber gasket. Thanks for the help.
