2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91678 07/03/2004 7:36 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | My horn gives the weakest little noise, even when I directly hook it to power. So it is not the wiring. My question is, would it be better to have it rebuilt, or find a used one to replace it? If rebuilding is the answer, anybody know of a good resource for this service? | | |
#91679 07/03/2004 9:50 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | If you're not going all-original, go to the scrap yard and pull something out of another vehicle.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#91680 07/15/2007 3:35 PM | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Brian,
I have a similar problem with the horn on my 52. I would like to keep the original horn if possible. Did you ever find someone to rebuild yours? If you bought an original replacement, where did you find one?
My dad always told me, "Don't force it, get a bigger hammer".
#91681 07/16/2007 10:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can take the cover off & file the points & adjust it. Sometimes that will fix it. If it,s 12 volts you can hide a new horn way down low & leave the old one on. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#91683 10/16/2007 6:11 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | You can check and see if this guy is still in business. He did some work for me about five years ago.
The Horn Shop Bill Randall 7129 Rome-Oriskany Road Rome, NY. 13440 315-336-8841 | | |
#91684 10/17/2007 3:05 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Mine didn't work at all. I removed the cover, the dome which pops off, cleaned up the points and adjusted them. The working adjustment range is very small and critical. My horns work really well now. | | |
