0 members (), 104 guests, and 5 robots.
Topics128,266
Posts1,058,386
Members48,485
#91678 07/03/2004 7:36 PM
My horn gives the weakest little noise, even when I directly hook it to power. So it is not the wiring. My question is, would it be better to have it rebuilt, or find a used one to replace it? If rebuilding is the answer, anybody know of a good resource for this service?
#91679 07/03/2004 9:50 PM
If you're not going all-original, go to the scrap yard and pull something out of another vehicle.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#91680 07/15/2007 3:35 PM
Brian,
I have a similar problem with the horn on my 52. I would like to keep the original horn if possible. Did you ever find someone to rebuild yours? If you bought an original replacement, where did you find one?
My dad always told me, "Don't force it, get a bigger hammer".
#91681 07/16/2007 10:37 PM
Riding in the Passing Lane
You can take the cover off & file the points & adjust it. Sometimes that will fix it. If it,s 12 volts you can hide a new horn way down low & leave the old one on.
1972 Chevy c10 Cheyenne Super
#91682 10/16/2007 5:09 PM
Brian,
Here is a place that claims to rebuild horns
But they are not cheap
http://www.classiccarhorns.com/index.html
#91683 10/16/2007 6:11 PM
You can check and see if this guy is still in business. He did some work for me about five years ago.
The Horn Shop
Bill Randall
7129 Rome-Oriskany Road
Rome, NY. 13440
315-336-8841
#91684 10/17/2007 3:05 AM
Mine didn't work at all. I removed the cover, the dome which pops off, cleaned up the points and adjusted them. The working adjustment range is very small and critical. My horns work really well now.
1951 1 Ton Completed
