2 members (Steveoreno, TPR57C), 106 guests, and 4 robots.
Topics128,186
Posts1,057,320
Members48,469
I converted to 12V a few weeks ago as part of the rebuild of my '52. I just got around to troubleshooting my horn and have made an interesting discovery. The horn would work for about 2 to 4 honks of 1 second each, then stop working. I traced the problem to the little cylinder that goes between the horn backing ring and the steering column. That piece has a spring inside to keep contact with the 2 locations mentioned above. The spring would get too hot and loose it's "spring" and collapse! The '52 did not use a relay and apparently 6 volts was OK, but not 12. Looks like I'll be rigging up a relay operation.
shoeless
Shoeless, I may be wrong, but i always thought the 6v spring looked to be about the same size as the later 12v springs. Maybe one of those would get you going again. The relay isn't a bad idea, either.
1954 GMC De Luxe COE
Riding in the Passing Lane
Wire a relay in it. There is to much curent for the horn button. smile
1972 Chevy c10 Cheyenne Super
Installed a relay today from Radio Shack that isolates the coil from the relay contacts. That was good medicine!
Junior Member
Junior Member
I guess I'll have to do the same or does the resistor between the ignition coil and ignition make up for the relay?
Quote
No that resistor has nothing to do with the horn or lights or such. The resister limits current across the points. Otherwise the current will quickly burn the points.
If you don't have a horn relay you need one.
he's right. do the relay. it's easy wiring. a couple of bucks at the auto parts.
Yet I'm still running my old 6 volt horn system on 12 volts with no problems. Going on 5 years and 20,000 miles now.
Fred
52 3600
69 C-10
