| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Hello, I have a 1953 3600 and I was just wondering would it be fairly easy to replace a column shift 3 speed transmission be replace with a 4 speed stick shift?
Were they fairly interchangeable back then or is it a can of worms?
Thanks, Dave
Me and my '53!
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | No problem switching to an SM420 4-speed with the torque-tube adapter on the back. Same length as the 3-speed. You would need the 4-speed forward u-joint yoke and the 3-speed rear u-joint yoke.
The speedometer drive and driven gears would most likely not give the correct speed. A ratio adapter can be obtained for about $100 or less.
| | | | | Joined: Apr 2012 Posts: 68 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 68 | Thanks Tim! Does not sound too bad
Me and my '53!
| | | | | Joined: Nov 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 35 | i have a 4 speed from a 216 from 41-43ish time and wat to put it on a 235 from 54 will it work or what do i need | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | i have a 4 speed from a 216 from 41-43ish time and wat to put it on a 235 from 54 will it work or what do i need You need to forget that and find an SM420. They are plentiful and cheap and will bolt right up. | | | | | Joined: Nov 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 35 | how about drive shaft and rear end then will i have to do anything there?
